Extension Socket
Extension Socket
Home Forums Workshop Tools and Tooling Extension Socket
  • #18076
    Vic
      @vic
      #236493
      Vic
        @vic
        I want an MT2 to MT2 extension socket for the head of my wood turning lathe but have only seen tanged versions. I need a threaded end for a drawbar, can you buy them?
        #236504
        John Reese
          @johnreese12848
          In over 60 years around metalworking I have never seen an extension socket without a tang. You could cut the tang off, drill and tap for drawbar threads. How will the tool be retained in the socket?
          #236517
          Martin Connelly
            @martinconnelly55370
            Could you drill a clearance hole through the extension and use an extended drawbar to pull the tool and extension together into the lathe? An extended drawbar should be easy to make.
            Martin
            #236527
            Ian Parkin
              @ianparkin39383
              The extension then would have no extraction facility
              #236529
              Muzzer
                @muzzer
                You could get around that by threading a bolt through the extension into the tool and giving the head a smart tap – or bumping it against a solid object like a vise.
                You'd have to be careful drilling a clearance hole through the extension, mind. You'd probably want to drill from the male taper end otherwise you'd be trying to open up a tang slot into a bore, buried at the bottom of the taper cavity…
                #236534
                Vic
                  @vic
                  Posted by Martin Connelly on 28/04/2016 09:05:45:
                  Martin
                  Are they soft enough to do this?
