exe lathe
exe lathe
Home Forums Manual machine tools exe lathe
  • #98336
    Nobby
      @nobby
      Hi Guys
      First cuts with no adjustments using travelling steady I made very pleased
      within a thou all the way along over 8 inches
      nobby
      exe lathe
      Edited By Nobby on 13/09/2012 20:29:24
      Nobby
        @nobby
        first cut using travelling steady
        #98338
          Great work, Nobby
          Nobby
            @nobby
            Cheers Michael
            I will have to make a micrometer dial for the X slide That little top slide I made for the other exe lathe I had Its 20 tpi so a 100 dial would be fine .
            Nobby
            #98363
            Ady1
              @ady1
              Way to go nobby
              Another one saved from the knackers yard
              #98428
              Sub Mandrel
                @submandrel
                Well done Nobby, Enjoy a virtual pint by way of celebration!
                Neil:
                #98453
                Nobby
                  @nobby
                  Hi Neil & Guys
                  I've made a micrometer dial for the lathe . but I should have given the stamping of the numbers more thought as i was not happy with them it spoilt the job . Cheers Neil i will have an half
                  nobby
