Mounting it on a lathe isn't a sensible way of testing it Dusty. That's why I set a myford spindle up in a V block. This removes any lathe spindle errors. There is too much test bar run out tested like that. And way way to much 50mm from the collet face.
I could check the taper run out in the V block but would have to be very careful not to allow any side to side movement so see that as a none starter.
There is no run out on the test bar or the myford spindle. Both can be checked in the V block and have been.
I then reversed things and mounted the test bar on the V block and checked the collet holder register for run out. Very little which could be down to either or both the collet or holder. Doesn't matter which. It's acceptable anyway.
The only explanation for this and the other measurements and tests is that the screw thread in the holder is off centre. This forces the collet holder to be off centre – any clearance between the registers is pushed over one way.
I've effectively ruled out significant problems with the test bar or collet.
I'm sleeping on sending it back for a replacement. The problem suggests that it's down to the way it's been made. Some effort has been clearly taken to align the register and collet taper but not sufficient on getting the thread central. This also explains why register sizes that should go in don't. The thread pushes the nose over as it's screwed in. The options are a refund or machine away the offending bits which would have to include the register even though it's ok and fit an insert that would be made in one setting – that hasn't been done on the thread in it otherwise it wouldn't have this problem. The problem – in some ways it would be easier to make one from scratch as the collet taper would be machined while it was on the spindle.
