ER collet chuck runout
Home Forums Help and Assistance! (Offered or Wanted) ER collet chuck runout
Viewing 13 posts - 26 through 38 (of 38 total)
  • #293599
    MW
      @mw27036
      Posted by mechman48 on 16/04/2017 12:15:14:
      ask how it got cracked, I have never ever tightened any MT tooling into the taper with any undo force, normally push the tooling in with a slight twist to engage both tapers then snug the draw bar up, so how it cracked is beyond me, ?? it beggars belief !
      TIA.
      George.
      Well it is a hardened spindle and It looks like a WM16 spindle nose, and whilst this would suffice to suffer far more stress than an unhardened one without bending, if a force large enough attacks it, it will just go all at once.
      I normally don't have any problems getting hold of the warco spares department by their telephone ext. They seem to respond better to this and they do call me if something was out of stock but has come back in.
      Michael W
      mechman48
        @mechman48
        Posted by Journeyman on 16/04/2017 12:22:40:
        George, what are we talking about here the WM250 lathe has an MT4 spindle! Is this a WM16 milling machine?
        ​Mea Culpa , yes, I meant it is my WM16 mill. IIRC the previous mentioned thread was akin to 'WM250 lathe & WM16 family… some years ago, I bought my machines back in 2012 & I think the original thread was started by Rik, or was it Thor… thinking
        Geo.
        Edited By mechman48 on 16/04/2017 13:43:38
        #293646
        Thor 🇳🇴
          @thor
          Hi George,
          The "WM250 & lathe family.." is here.
          Thor
          #293828
          mechman48
            @mechman48
            Just to clarify…
            ​It is the spindle on my WM16 mill that is cracked & am looking for any advice on spindle removal, disassembly, bearing change out ( angular contact, info, alternative ? ) etc. from anyone who has had similar problem with their Warco mill, plus any specific things to look out for. Being Easter not had anything back from Warco's, maybe tomorrow.
            TIA.
            ​George
            p.s. thanks Thor.
            Edited By mechman48 on 17/04/2017 23:25:03
            #294078
            mechman48
              @mechman48
              Spoke to Warco; bit the bullet & ordered a new spindle, + 2 bearings, according to Warco's spares dept. the bearings for the WM16 they stock for todays machines are tapered roller so…
              George.
              #301791
              mechman48
                @mechman48
                Update… finally got round to fixing the cracked spindle on my WM16; was dubious about getting bearings off etc as didn't have a bench press, just a small bearing puller, anyhow set to yesterday. Getting the spindle cartridge out wasn't a major deal, just a matter of looking at the exploded drawing from the manual , just a case of covers off compress the spring with a screwdriver, remove the 'C' clip… careful you don't let go of the spring, once that's out the cartridge slides down out of the splined drive gear … for a fuller description of bearing replacement look on YouTube… there is a nice video by Hossmachine on bearing replacement on a Grizzly G0704 which is the nearest equivalent to the WM16/18 …
                https://youtu.be/hP-XvbV7Pc4
                ​Following the video my self for clarity I managed to get the spindle out using the small bearing puller set, plus some 10mm screwed rod I had. I didn't take too many pics of the procedure as I wanted to get on with it & get it of my 2doit list. What I noticed on the original spindle was a heat marks around the area of the bottom bearing… what is this I ask? the bearing didn't show any heat marks… was it some form of heat treatment in manufacture, maybe hardening treatment of the MT2 taper end…? anyhow the spindle is out, a good wash out with white spirits, dry off & check over for any signs of damage.
                ​I refitted the new spindle with a pair of new taper roller bearings that I bought with new spindle, as per OEM, I didn't fit angular contact bearings ( ac ) as this would have meant messing about with shims to make up difference in outer race dimensions, a lot of YouTube videos show this but as part of upgrading to increase speed, which I wasn't planning on doing, so far I haven't needed to use higher than the 1200 rpm on the low range setting so no need for ac bearings. I have att. a couple of pics of the main procedure…
                Bearing puller prep'…
                Spindle pushed out of cartridge…
                ​Heat marks on spindle, no signs of overheating on bearing…spindle heat treatment ?… the blue is OEM grease…
                ​Old spindle out, new fitted, tools used…
                ​I repacked new bearings with high temperature lithium based grease rated for 4000rpm, suitable for pump shafts, wheel bearings & other high temp' applications, all it needs now is to run in for a while & check for any over temperature rise indications on casing, then it should be good to go… fingers, toes & everything else crossed
                ​George.
                #301792
                MW
                  @mw27036
                  Posted by mechman48 on 09/06/2017 13:20:18:
                  ​George.
                  Looking good, Mechman.
                  #301910
                  mechman48
                    @mechman48
                    Gave my WM16 a run in yesterday, checked collet run out… way less than .001"… I would estimate approx .0002" looking at the dti I used & it's running a lot quieter than previously…
                    #301911
                    Thor 🇳🇴
                      @thor
                      Hi George,
                      Glad to hear you got the spindle sorted, job well done. You have less runout then I have on mine.
                      Thor
                      #301921
                      Tim Stevens
                        @timstevens64731
                        It might be worth sawing or grinding the old cracked spindle to reveal the full length of the crack. This would show whether there was a flaw in the bar from which it was made. If so, the device could be described as 'not of merchantable quality' and (in the UK) you could then have a serious talk with your supplier.
                        You might find a talk with your trading standards office helpful, too.
                        Cheers, Tim
                        #301947
                        John Stevenson 1
                          @johnstevenson1
                          Touch that with a saw or grinders and no one is going to know you as you have messed with it.
                          As regards trading standards you also don’t stand a chance. They will have a maximum of 3 people to cover a whole county none of whom has a clue what a milling machine is and have more than they can handle just looking after fake CD’s and market traders.
                          Check out what I say before spouting the same old, post after post.
                          #301948
                          mechman48
                            @mechman48
                            Thanks Thor/Tim.
                            ​Tim, I can see where you're coming from but I won't resort to such drastic action, what I've decided is to contact an ex work colleague in the training centre I used to teach in, ask him to ask the welding instructor to clamp the spindle tight to close the crack, grind back to half depth wall thickness, & either Tig / Mig weld the spindle. I can then dress back the surface area, check the internal MT2 for any distortion and, all being well, keep it as a emergency spare spindle. Being a Yorkshire man 'waste not want not' if you follow my reasoning… must remember in future not to brag about not having any probs with my machines, don't want my arse bitten again…thinking wink
                            George.
                            #409286
                            Neil Lickfold
                              @neillickfold44316
                              So I got some ER11 collet nuts. Had a piece that needed to run quite true. When I used one of the new collet nuts, it was out by more than 0.05mm. Used the genuine ER nut and it was fine.
                              So I set up made a spacer and checked the original with my set up and the taper on the nut ran within 0.01mm, the new ones were out by as much as 0.1mm. So I set up and recut the 30 deg front taper using the thread and the back shoulder as a reference. Picture shows the inverted bore tool and the compound set at 30 deg. Using a Regofix ER11 collet holder with the sleeve spacer for the nut to seat against.
                              I also set up and trimmed the outside with it just on the thread of the mandrel 1st. Cutting the inner 30 deg taper was a second op.
                              Now they are just as good as the original collet nut.
