Engineering Origin of a Common Phrase?
Home › Forums › General Questions › Engineering Origin of a Common Phrase?
Viewing 25 posts - 1 through 25 (of 88 total)
  • #240630
      There are lots of examples in ordinary English of technical jargon entering the language. As a "loose cannon" I might "go nuclear", "let off steam", "tune in", be "between the devil and the deep blue sea", or commit myself "lock, stock and barrel".
      Yesterday I was aligning my milling machine ready to drill an accurately placed hole. My wobbler was spinning at 2400rpm when I bumped it causing the ball mounted pin to whiz across my garage and disappear into a pile of junk.
      After a fruitless search I lost my temper and walked off the job.
      Calming down later I realised that I had "thrown a wobbler" in two senses of the phrase!
      Does anyone "have the bandwidth" to tell me if the phrase "throwing a wobbler" has an engineering origin or not? Are there any other examples, perhaps "flying off the handle"?
      Thanks,
          "Balls Out" has its origins in the fact that governor balls swing out as the speed of an engine increases
          #240632
          mechman48
            @mechman48
            Something to do with gyroscopes not being balanced properly & wobbling out of true… 'throwing a wobbler'…? thinking
            I know 'going off half cocked' stems from in the heat of battle; if the old muskets weren't fully cocked after loading ( always loaded at 'half cock' then fully cocked for firing &nbsp the resultant discharge didn't have its full charge ignited, the flint barely capable of creating enough sparks in the frizzen pan to ignite the main charge…
            George.
            #240634
            Muzzer
              @muzzer
              Posted by SillyOldDuffer on 28/05/2016 13:13:22:
              Use an edge finder instead of a wobbler. They don't flail about as the end is captive and has limited movement. This is your opportunity to change!
              You probably know how to use an edge finder already but here's another video on how they work.
              Available from most sources. Arc Euro even give an explanation how to use them.
              #240635
              Bernard Wright
                @bernardwright25932
                Surely it's a 'wiggler' not a wobbler…. just saying
                Bernard.
                #240637
                Peter Hall
                  @peterhall61789
                  Not a wobbler, but if you slip whilst dismantling motorcycle switchgear and let the small spring fly loose, that's called a pingf*ckit, 'cos that's the sound you'll hear as it disappears into the darkest recesses of the workshop.
                  Pete
                  #240639
                  John Fielding
                    @johnfielding34086
                    How about the saying "a black art".
                    I know where it came from but how many others know its origin?
                    Incidentally a lot of the common sayings today are from Shakespeare's plays.
                    #240641
                      Posted by Bernard Wright on 28/05/2016 13:44:58:
                      Bernard.
                      Hi Bernard,
                      You just gave me a mild panic attack! It got worse when I tried to prove I knew what I was talking about. Finding nothing but "wigglers" in my various reference books, I was convinced I'd blown a gasket and had somehow imagined the stupid thing was called a wobbler.
                      Thankfully Chronos came to the rescue. Between them and a stiff sherry I'm feeling better now!
                      More good news – the missing wobbler pin has been found. Nowhere near where I thought it landed.
                      Cheers,
                        Posted by Muzzer on 28/05/2016 13:37:30:
                        Thanks Muzzer – good advice as always.
                        I didn't say so in the post, but the point I was aligning was on a 100mm diameter circular plate held by a rotary table. I tried using an edge finder to locate "North" and "West" on the plate but found it difficult to judge when the edge finder was truly at the farthest point on the circle. I admit I gave up too easily, and was left wondering if I'd missed a trick. Is an edge-finder a good tool for this?
                        I'm a self taught machinist and quite often end up kicking myself when I find out how the experienced chaps do things.
                        Thanks,
                        bricky
                          @bricky
                          The term cold enough to freeze the balls off a brass monkey,originates from when warships stored canonballs iniron monkeys on deck.The iron rusted and the two were stuck together.Making the monkeys from brass solved the rusting problem but in freezing conditions the brass contracted and popped the balls off.
                          Frank
                          #240671
                          John C
                            @johnc47954
                            Not model engineering, although maybe heavy engineering, but one of my favourites is 'throw a track'. This is from the armoured cavalryman's vocabulary and refers to a bad thing that happens to a tracked vehicle such as a tank. But I like the way it can be applied to any event that does not go as planned, or to the mental state of the poor unfortunate to whom the bad event has just happened!
                            duncan webster 1
                              @duncanwebster1
                              Someone will shoot me down over this, but I'm not sure an edge finder or wobbler works on a convex surface. As soon as it moves ever so slightly off centre, it will lose contact and so not 'flick'. An electronic one would work, I just use a bright light behind and move the tool until there is no gap. It's surprising how repeatable this is. If using an endmill you need to rotate the tool slightly to get contact at full diameter, it's obvious when you're actually doing it, not easy to describe
                              #240686
                                My electronic edge finder works on concave and convex surfaces, just lights up when it touches the surfacesmiley
                                Use it all the time to find ctr of circles – touch approx north and zero the dial, move y-axis only and touch approx south and half the distance. As this is a cord of the circle the half way point will be on ctr line. Repeat for east/West and you have the middle of your circle without worrying if you touched on teh exact extream of the edges.
                                #240693
                                  Posted by JasonB on 28/05/2016 20:44:28:
                                  Jason strikes again! I didn't realise that it's not necessary to find true North and true west. Of course half the chord must lie on the centre line. I can't wait to try it!
                                  How about "Nose to the Grindstone", "hammered" and "screwed up"?
                                  Thanks again guys,
                                  Eugene
                                    @eugene
                                    "Fast and loose" must be the most obvious (or not if you don't know the derivation.) Or "a screw loose".
                                    "Straight as a gun barrel" was common usage when I was a yoof, but that was in industrial Birmingham so maybe it wasn't current elsewhere. Another phrase from those days "He doesn't know if his a**e is drilled bored or countersunk" I still hear from time to time … Boris Johnson take note!
                                    "Only firing on three cylinders" is common enough as is "Nose to the grindstone". I've seen the balls off a brass monkey explanation before and don't believe it.
                                    Eug
                                    #240706
                                    Robbo
                                      @robbo
                                      "Strike while the iron is hot" – doesn't refer to a golf club!
                                      #240708
                                      Enough!
                                        @enough
                                        Posted by duncan webster on 28/05/2016 20:29:37:
                                        The electronic (well, electrical) type with a deflectable ball on the end works quite nicely in this situation and can be used whether the part is mounted horizontally or vertically but is very useful when the circular section is vertical (e.g. a horizontal round bar). Just feed backwards and forwards in the appropriate axis (in this case the z-axis …. use it like a drilling machine) while moving the part towards the centre finder until it just beeps.
                                        #240710
                                        Nick_G
                                          @nick_g
                                          Posted by JasonB on 28/05/2016 13:19:02:
                                          So nothing to do with secret inauguration ceremony into the Masons after all then. winkwink
                                          Nick
                                          #240718
                                            So that is what you they hide behind those little aprons then Nickblush When you have put it away what about an update on the Hogletquestion
                                            Bandersnatch my electronic finder has a 0.200" dia parallel end so don't even need to move it up and down when used against a horizontal round bar like you do with the ball ended ones
                                            #240723
                                            Jon Gibbs
                                              @jongibbs59756
                                              I always thought that "fast and loose" and "knocking off time" came from the same source and it certainly sounds a pretty good origin but "fast and loose" was used by Shakespeare in King John a few years before line-shaft machinery…
                                              KING PHILIP: Heaven knows, they were besmear'd and over-stain'd with slaughter's pencil, where revenge did paint the fearful difference of incensed kings: And shall these hands, so lately purged of blood, so newly join'd in love, so strong in both, unyoke this seizure and this kind regreet? Play fast and loose with faith? So jest with heaven…
                                              So, maybe it was reinvented.
                                              Jon
                                              #240727
                                              Ajohnw
                                                @ajohnw51620
                                                • Wobble –
                                                • A German word first used in English in the mid 17th century. Wobble is related to wave (Old English) andwaver (Middle English) which come from Old Norse, and until the mid 19th century was generally spelledwabble. To throw a wobbly is to have a fit of temper or panic. This is a recent expression recorded only from the 1960s, first of all in New Zealand, although throw a wobbler appears in the 1930s, in a US dictionary of underworld and prison slang. Wave did not come to be used for hair until the mid 19th century and the expression to make waves dates only from the 1960s. Mexican wave describing a wavelike effect when spectators stand, raise their arms, and sit again in successive crowd sections, originated at the World Cup football competition held in Mexico City in 1986.
                                                • John
                                                #240729
                                                Rik Shaw
                                                  @rikshaw
                                                  'Twas in a verse the bard once penned
                                                  At play with stick and noose
                                                  A tricky ploy to fool a friend?
                                                  A game called "fast and loose"
                                                  #240731
                                                    Fast & loose can also refer to flat belt pullies, a fast drive pully fixed to the shaft with a loose pully next to it that spins on te shaft so the belt can be moved from one to another when power is required or not
                                                    #240738
                                                    Nick_G
                                                      @nick_g
                                                      With Britain (at one time) being a sea fairing nation there are dozens of terms that have their origins originally from nautical sources in the language.
                                                      One being 'Two sheets to the wind' when somebody has consumed lots of alcohol. laugh
                                                      A sheet is the name given to the rope that holds the sail taught. There are 2 of them, port and starboard with only one on them taught at any one time depending upon which tack the ship is on. Upon the ship changing tack the tight one is made slack and as the ship transends through its heading the other is pulled tight.
                                                      For a short time during this transition both of these sheets (ropes) are facing into the wind. The sail they are attached to during this period flops and waves about in a semi uncontrolled way. ……….. A bit like someone who has had too many scoupes of beer. (or maybe rum)
                                                      Nick
