I wouldn’t have thought that the number of flutes would have much affect on the finish, assuming of course that you’re using a constant chip loading. The helix of the flutes may have more of an effect.
I have read about slot drills (traditionally two flute) cutting oversize slots, although I’ve never really noticed the problem. Keys are made to fit anyway; I think keysteel is normally supplied slightly oversize.
There is supposed to be a theory that cutters with odd numbers of flutes are less prone to chatter. I suspect that within the amateur workshop machine rigidity would be the over-riding factor.
On the manual vertical mill I tend to use a mix of HSS and carbide, two, three and four flute, depending upon what comes to hand at the time!
On the CNC mill I’ve standardised on 6mm and 10mm three flute uncoated carbide and 12mm three flute HSS rippa mills. Smaller cutters, special forms, different numbers of flutes and special coatings are used as required.
The vast majority of cutters I buy these days are centre cutting, whether they be two, three or four flute. I suspect this trend is driven by commercial use of CNC where the same cutter is used for all operations where possible and hence needs to the ability to cut on the sides and end.
All things being equal a cutter with more flutes should allow more material to be removed per unit time. However, the gullets (space between the teeth) are smaller and more prone to get jammed with swarf, so as in all things it’s a compromise.
Personally I think that three flutes is a good compromise between metal removal, swarf clearance and tool strength. And it’s what my local tool store sells!
Addendum: Here’s my take on Steve’s question. I think the distinction between end mills and slot drills is becoming blurred, and traditional endmills are dying out. For carbide cutters I use Garr, as they are stocked by the local tool shop. In their catalogue they only list endmills. I had a quick flick through the 90 odd pages of endmills, 2, 3 and four flute, and as far as I can see they are all centre cutting.
Edited By Andrew Johnston on 21/08/2011 22:23:30
