ELLIOTT OMNIMILL
ELLIOTT OMNIMILL
Home › Forums › Manual machine tools › ELLIOTT OMNIMILL
  • #421244
    Geoff MEDCRAFT
      @geoffmedcraft72477
      I have an Omnimill and a cover for the pulleys and belts. Sadly it was never fitted when I bought the machine, I am trying to understand how it is fitted.
      I appreciate it is bolted at the front but is there any support to the rear by the motor. My cover seems to rest on the grease nipple at the intermediate/middle pulleys is that correct or is something/bracket missing.
      Any photos or guidance much appreciated
      Geoff
      #13598
      Geoff MEDCRAFT
        @geoffmedcraft72477
        #421332
        Ian McVickers
          @ianmcvickers56553
          Have a look at my Omnimill rebuild album. There are two photos with the vertical head assembly in place without the cover fitted. There is a vertical shaft fitted to the motor support bracket. The cover sits on top of it and has a bolt to hold it in place.
          #421341
          Geoff MEDCRAFT
            @geoffmedcraft72477
            Ian
            Thanks so much for taking the time I see what you are referring to and I will have a look tomorrow.
            I will leyt you know
            Thanks Geoff
            #421597
            Geoff MEDCRAFT
              @geoffmedcraft72477
              Ian
              Great found it 1/2' UNC so I can now make a support.
              Certainly loved the restoration on your Omnimill, a good friend as a pastime does single to 3 phase phase convertors and designed and built on for my machine. Brilliant with the speed control, he also modified the existing table motor for single phase.
              Thanks
              Geoff
