Electric motor selection
Home › Forums › General Questions › Electric motor selection
  • #266555
    Rik Shaw
      @rikshaw
      Some time ago I asked a stockist of 3 phase 6 pole motors on ebay whether his 1hp job would be OK on my shaper if used it with an inverter.
      He told me that it would not do as his particular motor was designed for slow starts as used in fans etc.
      He DID however tell me the sort of 3 phase 6 pole motor that WOULD do and I have completely forgotten what he told me.
      What do I need to look for in the motor description that will indicate the correct “fast start” motor I am looking for?
      NOTE: I need the 6 pole job as the speed (950 rpm approx) will drive the shaper at the correct speed. Also, the reason I am going down the 3 phase / inverter route is because it has proven impossible to buy a 1hp single phase 6 pole motor which of course would also give 950ish rpm.
      Rik
      #24868
      Rik Shaw
        @rikshaw
        …….getting it right!
        #266556
        duncan webster 1
          @duncanwebster1
          It might be a lot cheaper to buy a 4 pole motor and just run it slower from the inverter, or even change the pulley size on the motor.
          #266560
          mark smith 20
            @marksmith20
            Why not this? Sorry its only 3/4hp,
            Edited By mark smith 20 on 14/11/2016 14:52:56
            #266563
            John Rudd
              @johnrudd16576
              Posted by duncan webster on 14/11/2016 14:21:12:
              Running it slower would reduce the airflow through the motor? The pulley option may be a better solution…..
              As for slow starting, vfd's I have used have a start up ramp that can be changed……I guess it depends on what is meant by 'slow start' ?
              #266586
              Rik Shaw
                @rikshaw
                Just thought that I would mention that the motor pulley is about as small as it can be so that option is ruled out.
                Rik
                #266696
                Ian S C
                  @iansc
                  The other pulley could be made larger. The 6 pole motor is going to cost a good bit more than a 4 pole, even if you have to put a jack shaft in to get the speed down.
                  Ian S C
                  #266700
                    Posted by Rik Shaw on 14/11/2016 16:52:12:
                    Rik,
                    Have you considered using PolyVee ?
                    Ajohnw
                      @ajohnw51620
                      I couldn't get anything in writing of the makers but I went through this with the motor on my lathe. I fitted 6 pole to reduce the revs and then ran the inverter at a frequency to get the same rpm as a 4 pole. Most motors are rated to run at 60Hz anyway so that's part way there. You might find something like inverter frequencies from 40 to 80hz are adequate most of the time. I don't see much risk of overheating etc even with long running times under heavy loads. I did as many do uprate the motor HP though. Fitting a 1HP to an ME10 was rather tight. Had to use high tensile M4 in places. In real terms I suspect 3/4hp would have been adequate.
                      This makes more sense to me as it retains torque more when the speed is reduced.
                      Rik Shaw
                        @rikshaw
                        "The other pulley could be made larger"
                        'Fraid not Ian, the large pulley is part of the clutch mechanism.
                        Michael – The V drive belt on this machine is on steroids with a cross section big enough to be the fan belt on a bulldozer. Full marks for imagination though wink
                        John – Some interesting info there, thanks.
                        Rik
                        Edited By Rik Shaw on 15/11/2016 17:57:18
                        #266753
                          Posted by Rik Shaw on 15/11/2016 17:50:09:
                          Rik,
                          Guess what sort of fan belt they are using on bulldozers these days
                          https://xtboshuo.en.alibaba.com/product/60556759927-800852639/3040292_engine_parts_fan_belt_poly_belt_for_bulldozer_fan_and_water_pump.html
                          Edited By Michael Gilligan on 15/11/2016 19:48:24
                          #266772
                          Rik Shaw
                            @rikshaw
                            Thanks Michael – Very interesting I'm sure but I am really looking for help of a less "general" nature.
                            Rik
                            #266776
                              Sorry if I have misunderstood your requirements, Rik
                              Mine was a serious suggestion, made in response to your comment that further reduction of the motor pulley diameter was 'ruled out'. A poly-vee belt capable of transmitting one horsepower would probably run comfortably on a one inch diameter pulley [which a chunky vee belt will not]
                              … I will leave you to it.
