Dummy Rivets
Dummy Rivets
Home Forums Beginners questions Dummy Rivets
  • #321904
    Phil H1
      @philh196021
      If I really do want to insert some cosmetic snap head rivets into a buffer beam with no access at the back for a countersink – what is the best technique – a blind hole and Loctite? Or sit down in a dark room for an hour and stop counting rivets on the real engines?
      Phil H
      Phil H1
        @philh196021
        #321906
          A bit rash. Loctite is the obvious way but now you've posted everyone will know you didn't fit them first.
          Clive Brown 1
            @clivebrown1
            An alternative might be hammer -drive rivets, steel, round head rivets with a fast helix on the shank to secure them. Available in a range of sizes, but you'll need to match the head size with the existing rivets, otherwise they'll stick out like sore thumbs.
            Edited By Clive Brown 1 on 17/10/2017 11:13:29
            #321926
            MW
              @mw27036
              Yes I would agree with using an adhesive of sorts as well as riveting pop rivets blind, the fit on them isn't always that secure with just a rivet.
              Otherwise, depending on how much material you can sink into, you could turn some custom dummie heads with a taper pin on the back, of course you'd need a taper pin reamer as well to make the seat, but that's the only other way I can think of doing that.
              Edited By Michael-w on 17/10/2017 12:21:19
              #321931
              pgk pgk
                @pgkpgk17461
                Depending on size and material types how about splitting the rivet shaft, insetting a wedge so when you hammer it in the shaft expands?
                #321938
                Phil H1
                  @philh196021
                  Thanks chaps so far. The rivets are likely to be 3/64" diameter so that limits my options. I was thinking of some form of interference e.g., drill the hole as normal and perhaps crimping the rivet shaft. This might give sufficient space for the glue and a tight mechanical fit.
                  I guess my question is for a product like Loctite – is the best approach for an optimum joint to have a nice clean hole and nice round shaft or will a crimped shaft work better?
                  Phil H
                  #321951
                  Bob Youldon
                    @bobyouldon45599
                    Hi Phil,
                    Having done it in the past with 3/64" rivets drill a 3/64" hole if posable right through drop a little high strength Loctite in the hole with a pin and pop the rivet in, it may pay to ensure the rivets are free from grease and oil, give then a wash in a drop of soppy water rinse and dry them on a tin lid on the cooker, it'll work every time, don't worry if there's a spot of surplus loctite around the head, wait for it to go off and clean the job up with a rotary wire brush.
                    Bob
                    #321960
                    Clive Hartland
                      @clivehartland94829
                      I have been looking for that' 'Soppy water' for ages. Let us know where you get it Bob.
                      #321962
                      Harry Wilkes
                        @harrywilkes58467
                        EKP fasteners do slot less round head screws in BA sizes link
                        H
                        #322015
                        Samsaranda
                          @samsaranda
                          If the round head screws are slot less and going into a blind hole, Phil h states no acces at the back, how are the screws driven into a tapped hole?
                          Harry Wilkes
                            @harrywilkes58467
                            Posted by Samsaranda on 17/10/2017 20:34:36:
                            Dave after making sure the tapped hole had a good thread and was clear I used a pencil with a rubber on the end, a slight counter sink helped wink
                            H
                            #322030
                            Phil H1
                              @philh196021
                              The round head slot less screws are a good idea but they would need to be smaller than 12BA. Sound like a great idea for larger scale engines.
                              Thanks for all the help chaps. I will think about whether I should add the extra detail and use the very clean hole, and Loctite described by Bob if I decide to go for it. I will of course post pictures in the future – either way.
                              Phil H
                              #322032
                                Is there no way of fitting them before attaching the buffer beam?
                                duncan webster 1
                                  @duncanwebster1
                                  pressed wrong button!
                                  Edited By duncan webster on 17/10/2017 22:30:56
                                  #322045
                                  Phil H1
                                    @philh196021
                                    Neil – sorry no.
                                    If you look at most steam locomotive pictures, there is usually a line of rivets very close to the top of the beam. On many model engines at say 3 1/2" gauge, the beam is angle so the rivet hole would go into the angle web – so the drill never breaks through (hope that makes sense).
                                    Options are;
                                    – leave them out and don't worry – as most models – so who would criticise anybody for omitting them? After all, building an engine to the model drawings and finishing the model is an achievement.
                                    – perhaps use a thicker plate for the beam as some 5" gauge engines and change the model design slightly i.e., shorten the frames slightly and mill the extreme ends to look thinner.
                                    – Use glue as suggested.
                                    Phil H
