Posted by Andrew Johnston on 19/12/2017 22:46:54:
I simply don't see the need for a DRO on the lathe.
Most of the time that's true, but it does depend on the operator. I doubt I'm the only one who makes silly mistakes!
Normally I use a digital caliper to calculate how much metal needs removing and use the dials to get with 0.4mm of target. Then I remeasure before finishing off carefully with the dial.
Usually that works perfectly, but every so often I lose count roughing out and over-shoot. Very frustrating to find I've removed exactly a mm too much, let alone two!
The other advantage of a DRO for me would be screwcutting, where it would speed up re-setting and eliminate backlash mistakes.
That said, most of the time I manage perfectly well with dials, digital caliper and a micrometer. While a DRO on my lathe would make life easier, I have better things to spend my money on.
