Drawing for a miniature quarter turn valve
Home Forums General Questions Drawing for a miniature quarter turn valve
  • #26682
    Brian Abbott
      @brianabbott67793
      Brian Abbott
        @brianabbott67793
        Hello.
        Does anyone know where i can find a drawings for a miniature quarter turn isolation valve ?
        Thanks.
        Edited By Brian Abbott on 23/06/2019 20:55:51
        #415802
        Brian Sweeting 2
          @briansweeting2
          Are you looking for construction drawings or layout drawings, also what size miniature?
          Basic valve layout/data …. **LINK**
          Edited By Brian Sweeting on 23/06/2019 21:29:20
          #415805
          Brian Abbott
            @brianabbott67793
            Hello.
            I need to make a replacement injector isolation valve, many of the comercial places make them but i need one with a flane mount, what i am after is a design i can adapt.
            Edited By Brian Abbott on 23/06/2019 21:42:36
            #415808
            Nigel Graham 2
              @nigelgraham2
              Note that the link opens the details for the sort of valve common on plumbing systems, and these are very simple but highly restrictive to flow.
              I sectioned one recovered from 15mm plumbing, to see if it's possible to make a miniature version, and found the port through the ball is half the pipe bore, so one-quarter cross-sectional area!
              The operating spindle has a screwdriver-like tip that engages a shallow slot cut across the ball (verify the orientation before slotting).
              The spindle is captive by a shoulder, so the valve is assembled by inserting the spindle from inside, then putting in the far O-ring seating, the ball itself turned to the slot engages, the near O-ring then a special circlip that locks into a groove in the valve wall.
              A friend in the plumbing-trade vouched for the restriction they offer, but said full-flow versions are available.
              It ought be possible to make full-flow versions for much smaller pipe sizes; though rather fiddly to machine. I'd use a manufactured bronze or stainless-steel ball, but I don't have a ball-turning attachment. Besides, it is likely to be of greater accuracy and sphericity than I'd hope to achieve!
              To replace the circlip with something easier I'd be tempted to use a thin push-fitted sleeve trapped by the end-fitting or union, but beware the risk of losing the internal components when disconnecting the fitting.
              Alternatively look on the boiler-fittings drawings for almost any miniature steam locomotive or traction-engine. The quarter-turn valves on these are usually plug-cocks, but you should find a design you can adapt to your needs.
              #415820
              duncan webster 1
                @duncanwebster1
                Posted by Brian Abbott on 23/06/2019 20:53:12:
                Hello.
                Thanks.
                I'll send you one tomorrow when I can prise SWMBO off the other computer. you'll have to pm me your email address
                #415839
                Paul Lousick
                  @paullousick59116
                  Globe valves and ball valves can also be used for controlling steam supply to injectors. If you need a flanged type valve, a commercially available valve could be modified by screwing or silver soldering onto a flange.
                  Paul.
                  #415845
                  Brian Abbott
                    @brianabbott67793
                    Thanks guys,
                    Duncan, will drop you my email address.
                    Thanks,
