Draughting Pens
Draughting Pens
Home Forums Workshop Tools and Tooling Draughting Pens
Viewing 6 posts - 76 through 81 (of 81 total)
  • #240372
    Danny M2Z
      @dannym2z
      Posted by Andrew Johnston on 24/05/2016 22:54:13:Here are some closer shots of the elevations:
      Andrew's drawings have a subtle quality and warmth that a cold CAD program could but hope to reproduce.
      Maybe not technically perfect but quite usable and easy on the eye.
      It's quite difficult to explain why, but I like them as a work of engineering art.
      * Danny M *
        Posted by Andrew Johnston on 26/05/2016 11:44:59:
        Posted by JasonB on 25/05/2016 07:24:31:
        PS could you provide one dimension so an idea of size could be worked out, say flywheel diameter
        Jason: Flywheel diameter measures as 7.5".
        And if you want scale, I suspect those brown rectangles at the bottom will scale to just under 9" long and 3" high – allowing for mortar
        #240392
          Posted by Neil Wyatt on 26/05/2016 14:05:28:
          Bit blurred but there's a scale in the lower right hand corner of the drawing. I think it says 1 1/2 inches to the foot which makes 7.5" mean the engine has a 5 foot flywheel.
          #240396
            Posted by SillyOldDuffer on 26/05/2016 14:46:06:
            And makes the bricks 8.5" long, looks like they left the mortar out
            #240398
              Posted by Neil Wyatt on 26/05/2016 15:24:50:
              Hiatus maxime deflendus!
              #240399
                Neil, being in the construction industry I know all to well the variation in old imperial bricks so they can only be taken as a rough guide.
                Thanks Andrew for confirming a known item looks like 2" scale or 1/6th would be a nice size to model it in and a 10" flywheel will fit nicely on the lathe, though it's not quite such a nice scale to get to suit nominal sizes, the original 1/8 of the drawing is better for that.
                Also good to know that all that macheneryu and tooling in the house is doing a good job blocking out the daylightwink 2
