Doublesided Louvre Presstool
Home › Forums › Workshop Tools and Tooling › Doublesided Louvre Presstool
  • #272277
    vintagengineer
      @vintagengineer
      Anyone know how to make a double sided louvre press tool?
      #18321
      vintagengineer
        @vintagengineer
        #272281
          To be honest, I don't even know what a double sided louvre would look like.
          … I thought louvres were [almost by definition] single sided things.
          Have you got an explanatory picture ?
          vintagengineer
            @vintagengineer
            They are like single sided louvres but they look like normal lovures but when you look at the panel both sides look the same.
            #272285
              Thanks for that
              … Food for thought
              Edit: … any hints here ?
              http://marquerestoration.com.au/louvres/
              Edited By Michael Gilligan on 16/12/2016 21:43:21
              #272287
              vintagengineer
                @vintagengineer
                #272330
                  dont know … This could turn into a difficult conversation
                  Perhaps someone else can advise.
                    I thought your link was correct Michael, the results are what I thought the OP wanted – louvers both sides but that actually look like a single row when viewed.
                    The same profile could be made on a longer press tool and die if the OP wanted a set louver length or as the link to make infinite lengths
                    J
                    Edited By JasonB on 17/12/2016 09:43:53
                    #272336
                    clogs
                      @clogs
                      Hi all,
                      are u sure there's nobody (firm ) with a set…….I seem to remember a specialist (Aston Martin) body fabrictor around the Mill Hill area of North London……also, somebody make replica bodies for S/charged 31/2lL Bentley's around Bristol…
                      other than that, loads'a fun and many hours to make ur own………
                      hope this helps, of course u could have a holiday in Bombay……it'll be done for when u fly home……
                      good luck Clogs
                      #272339
                      Circlip
                        @circlip
                        When you've pressed all the louvres on one side, turn panel over and repress on other side. Panel is already pierced so you're only depressing the hump into the second side.
                        Regards Ian.
                        #272455
                        vintagengineer
                          @vintagengineer
                          Thank you for the link that is exactly what I needed. Principle is the same, just got to make tool to fit the louvre drawing!
                          Posted by Michael Gilligan on 16/12/2016 21:24:20:
                          Thanks for that
                          … Food for thought
                          #272461
                            Posted by vintagengineer on 17/12/2016 20:44:04:
                            Glad I could help … I was a bit worried by what I thought was your intital response.
                            … presumably our posts crossed out there in the æther !!
