If planning to flycut a lot of car heads I would first do a check of the mill to be used, using an old scrap head. Do the cut as you usually would but first jury rig a dial indicator under each end of the table, and watch them during the cut at the outer extremes of table travel. The indicators should be rigidly supported from the machine base or the floor if the mill is bolted down. If table is deflecting more than a few thou during the cut, your milled head won't likely be flat enough, and you may need extra support of the table to the floor or mill base before doing non-scrap ones.
In many automotive machine shops I have been in ( since I started going to these shops in late 1960's as a kid picking up parts for my grandfather and Dad's garage, later getting my own project work done) I noticed the mills used for flycutting/face milling blocks and heads have especially wide bases supporting almost the whole table length. This was done for maximum rigidity to assure a flat cut on decks of the large and heavy workpieces.
Edited By Jeff Dayman on 30/10/2017 15:43:15
