Do you think anyone will notice
Home › Forums › Beginners questions › Do you think anyone will notice
Viewing 3 posts - 26 through 28 (of 28 total)
  • #170972
    Ian P
      @ianp
      Posted by Chris Trice on 29/11/2014 01:26:37:
      For an organic material that swells and shrinks with temperature and humidity, overly critical tolerances seem a bit OTT.
      I can assure you the tolerance was relevant for the job. 0.05mm was only applied where it needed to be.
      As you observe wood is not a completely stable medium, but the top of this table is constructed as a sandwich on aluminium honeycomb core. Veneer/mdf/hexalite/mdf/veneer were bonded under pressure then passed through a full width sanding and thicknessing machine. The 50mm or so perimeter of the top is actually a hardwood frame so the critical areas where thickness differences would be noticeable are subject to ambient conditions, but are sealed by lacquer. As long as both thicknesses shrink or swell at the same rate the actual dimension does not matter.
      Ian P
      #171135
      nigel jones 5
        @nigeljones5
        Neil has shamed me into swapping it all around, and I now have to make lots of shiny new parts as nothing now fits…….like anyone would ever have known but the two of us!
        #171151
        Chris Trice
          @christrice43267
          You'll feel so much happier when it's done fizzy.
