colouring brass
colouring brass
Home Forums General Questions colouring brass
  • #130955
    Gordon Wass
      @gordonwass
      I made a small model ships cannon from brass, about 6" long. I want to stain/ colour it to look a bit more like bronze. All my books have recipes using white arsenic and similar materials. Was going to try ammonia but can't even get that at any shops round here. Does anyone know a method using common materials ? I have thought of chicken manure, I have that, but not sure of results. BTW no need for perfection, it's only a filler piece.
      Gordon Wass
        @gordonwass
        #130956
          Gordon,
          You might find inspiration here
          or here
          Edited By Michael Gilligan on 29/09/2013 10:08:10
          #130960
            You could also pee on it.
            #130961
            Keith Long
              @keithlong89920
              Also worth looking for Carrs metal balcking for brass – used a lot by the model railway folk. I've used it on brass for outdoor use and it stands up fine to the exposure.
              Keith
              #130965
              Gordon Wass
                @gordonwass
                By, that was quick! The steam punks come up with some ideas, might try chicken muck, I'm not in a hurry. Prefer Jason's, will show to wifey and tell I must go to pub first. Thanks.
                #131001
                jason udall
                  @jasonudall57142
                  Ahh.when I read post.though you were aiming for bronze as apposed to brass. Ie more coppery..now I see you are aiming for “antique” bronze…there are some very effective antique ing solutions available….
                  Most start where I was going to lead you..mild acid..citric or vinegar.in our case..this will remove some of the zinc from the surface layers…leaving the surface coppery. .this is aged with other agent’s. .
                  As to chicken poop…active ccomponent ammonia ..a component in brasso…draw your own?conclusion ?in
                  #131002
                  Engine Builder
                    @enginebuilder
                    I haven't tried this myself but a friend gets good results blakening brass with a 50 : 50 mix of ammonia and domestos bleach. He says other makes of bleach do not work as well.
                    #131014
                    Springbok
                      @springbok
                      hi come down to my farm all free range bring a large shovel and you can have as much hen poo as you can take away F R E E….. (Hope people do not mind the smell in your car) will even give you some eggs
                      citric acid diluted is good.
                      Jason only do it if neighbours are out…
                      have fun
                      Bob
                      #131018
                      Gordon Wass
                        @gordonwass
                        Will try the vinegar and salt mix and see what happens, nothing much to lose. Trouble is can't easily get all the exotic solutions suggested , can't even find ammonia solution. Could get everything on line but it's just a one off, well for now. Plenty of organic solids and liquids round here, thanks for the offer tho'.
                        #131051
                        Loose nut
                          @loosenut
                          Try Liver of Sulphur (avaialble on ebay) small doses diluted with water ages. brass & copper..
                          #131117
                          daveb
                            @daveb17630
                            Many supermarkets stock ammonia, look in the household cleaners section, it's used (diluted) for removing wax polish from floors. Many years ago (not knowing any better) I took a good sniff of this stuff, was a bit like being hit on the head with a brick, from the inside.
                            jason udall
                              @jasonudall57142
                              called "liquid ammonia"….actually a soluion in water… and this is the stuff you want
                              ammonia can be liquified but at room temperture needs high pressure….you will see tankers of it on roads..
                              #131134
                              Gordon Wass
                                @gordonwass
                                Thanks , know about ammonia solution and etc. even from my young days with iodine. Strange thing is lots off stuff used to be available just about everywhere. Nearest supermarket to me, about 20 miles does not have it. Whent to village chemists and the helpful lady looked on a data base and could not find anywhere near that stocked it, but did offer to order 5 ltrs for me. Don't sell sodium silicate now ( water glass ) either.
                                #131149
                                modeng2000
                                  @modeng2000
                                  Amonia is what the liquid was in the little bottles of 'Smelling Salts' that used to be available for clearing the nose etc.
                                  #131185
                                  jason udall
                                    @jasonudall57142
                                    I think “smelling salts” was ammonium carbonate a solid that dis assccociates into CO2 and ammonia NH3….. but who cares can’t buy that in chemists either.
                                    #131551
                                    Gordon Wass
                                      @gordonwass
                                      A little update on colouring brass. Tried the vinegar and salt method, nothing except a cleaner bit of brass, yellowy colour, maybe the vinegar was old. Found, in a tut shop, stuff called Kleen Off, by Jeyes. This seems to be ammonia. Some in bottom of jar, brass bit in the fumes, lid on, next morning all nice and dark brown. Cleaned up and another shot will be done tomorrow. A bit of rub with oily rag will look like 17C job.
                                      #131611
                                      jason udall
                                        @jasonudall57142
                                        Thanks for update.
                                        #135332
                                        modeng2000
                                          @modeng2000
                                          Gordon,
                                          How durable is the resulting coloured surface?
                                          Jerry Wray
                                            @jerrywray14030
                                            These are the kiddies, give them a try, you might get a sample quantity if you are lucky.
                                            They produce some of the most sophisticated coating systems that exist.
                                            JerryNotts
                                            #135342
                                            Sub Mandrel
                                              @submandrel
                                              Slightly off-topic, but google 'golden book chemistry' for memories of an age when you could let pre-teens loose with ammonia, carbon tetrachloride, hydrochloric acid and a warning to 'be careful'.
                                              modeng2000
                                                @modeng2000
                                                I have a book called Manual of Formulas. Some of the ingredients are scary to say the least!
                                                It does have a few recipies for colouring metals.
                                                Gordon W
                                                  @gordonw
                                                  Coating after exposure to the ammonia fumes seems durable, but is only for decoration so not really tested. I grew up with all sorts of chemicals, most could be bought easily, ether, sulpher, sod. chlorate and nitrate, carbide, etc. etc. Also access to fog detonators, found a Webley pistol with a box of ammo. once, maybe lucky they were all badly corroded.
                                                  #135425
                                                  John McNamara
                                                    @johnmcnamara74883
                                                    There is an excellent chapter on colouring various metals contained within the following 2 volume set.
                                                    Google:
                                                    The Modern Gunsmith James Virgil Howe
                                                    This man was the director of the Frankford Arsenal in the US. Printed in 1941 it is one of the best books on precision toolmaking I have ever read.
