Cold casting shape with least finishing
Home Forums General Questions Cold casting shape with least finishing
  • #266575
    Mark Pearce 1
      @markpearce1
      I want to cast some barrels for a friend (1 inch diameter, couple of inches high), I'm in two minds though.
      I made a one piece mould and it seemed easy, but achieving a perfectly flat base is driving me mad.
      I've tried resting a heavy, flat object on top of the polyurethane resin as it sets, which seems reasonably successful, but it's still a fiddly job when there's so many to make, and sometimes creates awful airbubbles- just wondering if there's an easier way?
      One idea I had was to make a base sepeeratley and insert that into the end of the one piece mould as it cures- unsure if that would work??I thought maybe a two piece mould might be more successful, but I'm not sure, i'll end up with a sprue to irritate me instead!
      Thanks for any help at all,
      Mark.
      #24869
      Mark Pearce 1
        @markpearce1
        #266576
          Cast the item upside down and have a riser, when set saw off the riser and sand the base flat. That is the way model figures are usually cast and the maker than has to prep the mating surfaces.
          #266595
          Mark Pearce 1
            @markpearce1
            Thank you for the kind reply. Great information. Do you think I could also make flat things this way(like a coin or disc-6mm thick)-if so would I have the piece parallel or perpendicular to the riser?
