Cleaning and preparing a new to me, old lathe
Home › Forums › Manual machine tools › Cleaning and preparing a new to me, old lathe
  • #421883
    Del Greco
      @delgreco45469
      So, I didnt want to hijack this thread: #Cleaning a new lathe# so thought i'd make a fresh one.
      I'm almost set to start playing with my new to me 1950s lathe, and wanted to check what level you guys do a strip down / clean up / grease up etc, before starting to do any work.
      I've given the drip tray a complete wash with typical fairy, to remove the grime from the last owner, however, most of the machine has a light oily coating on it, and the bed seems to have a suitable film of oil on it too.
      I was just wondering if I should clear all the old oil/grease/cack off the machine and then do my own lubrication with fresh oil/greases/etc, or if that is a bad idea.
      Many thanks in advance.
      Del
      #13602
      Del Greco
        @delgreco45469
        Recently purchased. What level of work should be done to ensure it is well oiled etc
        #421887
        roy entwistle
          @royentwistle24699
          Just don't forget that what look like grease nipples on a Myford are for oil not grease
          Roy
          #421903
          Del Greco
            @delgreco45469
            Posted by roy entwistle on 31/07/2019 15:58:55:
            Roy
            Very good point yep. I've been cleaning each of them as I work around the lathe. Hoping to have it purring quietly very soon.
            #421926
            HughE
              @hughe
              Welcome Del ,
              Bit late . I have the same S7 as you. Lots of info on this site about it and suggested reading. Do the setup when in its in its final location as the bench it not the sturdiness of benches. It took me about 3 goes before things settled down.
              Last year I carried out a VFD 3 phase conversion, it's a worthwhile upgrade that you wouldn't regret.
              I also have some spares left over from a gearbox upgrade, so if you need anything PM me to check if I have it.
              Hugh
