Clarke CL430 Metal Lathe
Home Forums Workshop Tools and Tooling Clarke CL430 Metal Lathe
Viewing 25 posts - 1 through 25 (of 43 total)
  • #363231
    Brian Davies 6
      @briandavies6
      Hi , my lathe which is a
      Clarke CL430 Metal Lathe has a problem ,when I turn on the auto feed the thread bar turns fast and slow so I know the the switches are working ok all the belts and cogs turn all is working behind the cog/belt door but the cutting head will not auto run ,if I turn the auto off I am able to move the cutting head manually ,I can not find any one to repair it has any one got any info that will help me ,thank you Brian from West Yorkshire
      Brian Davies 6
        @briandavies6
        #363235
          Have you moved the lever on the lower right of the apron (circled red) , this will engage the rotating  feedscrew with the carrage
          Edited By JasonB on 21/07/2018 18:20:20
          #363236
          Brian Davies 6
            @briandavies6
            Hi Jason , yes I have done as you say , I forgot to say in post that I have had this lathe quite a long time and it’s been working perfectly it’s just stopped working as it should today
            #363243
              I'd use a mirror to peer under the swarf guard covering the lead-screw to see if the half-nuts are engaging or not. The mechanism is quite simple; the lever operates a threaded clamp that grips the leadscrew to move the saddle. The nuts may be worn or out-of-adjustment (look for damage and an adjusting screw).
              Another possibility is that a sheer pin has snapped in the black collar on the left hand side of the leadscrew. (The collar connects the leadscrew to the gears and belts. Because a common mistake is to crash the saddle into the headstock, the collar is fitted with a brass pin designed to snap and disconnect the leadscrew. It's not unusual for the pin & collar to retain enough friction to turn an unloaded leadscrew, but it stops immediately the auto lever is engaged.)
              Edited By SillyOldDuffer on 21/07/2018 18:56:32
              #363244
                Nuts can also gt clogged with swarf.
                #363266
                martin perman 1
                  @martinperman1
                  Gentlemen, the lathe doesn’t have half nuts on that lever, that lever clamps the traverse so the slide way doesn’t move. The lever that drives the shaft is out of picture on the left. I would look to see if you have sheared a pin in the black connector bar on the end of the shaft before it disappears inside the head stock.
                  Martin P
                  #363271
                  Howard Lewis
                    @howardlewis46836
                    Quick check. With the chuck rotating, does the leadscrew rotate?
                    (Insulting question: you have got the tumbler reverse engaged in Forward or Reverse, rather than in Neutral?
                    Or there could be problem with the change gears – missiing / sheared key?
                    If NO suspect the shear pin in the drive. (possibly the victim of engaging the half nuts with the saddle locked!)
                    If YES, the problem would seem to be within the saddle.
                    Does the operating lever actually open/close the half nuts? NO, Find out why. (lever not rotating shaft / shaft not opening/closing half nuts)
                    It does happen!
                    Some time ago, I thought that my lathe had major belt slip problems. Turned out that the inner lever tensioning the belt was slipping on its shaft (Too shallow a dimple in the shaft for the grubscrew to engage. A fairly easy problem to cure).
                    #363277
                    richardandtracy
                      @richardandtracy
                      Brian, I have one of these and the Warco equivalent. No half nuts, it's a simple lathe, so don't worry about these features that others above are used to, but this lathe doesn't have.
                      My suspicion falls on the shear pin in the leadscrew.Try, with the motor off, engaging the leadscrew. Now, using the leadscrew handwheel on the right, does the leadscrew turn? If yes, then something has sheared. If no gears turn in the drive belt box it's either the shear pin or dog clutch that's failed. Hopefully it's only the shear pin in the black connector shown on Jason's photo above at the extreme left end of the leadscrew. If it's not that, follow the rotating drive train as far as possible towards the chuck to find the last bit that rotates – then it's the next bit that's failed. You can probably make a spare yourself, with luck!
                      Richard.
                      #363283
                      Robbo
                        @robbo
                        A look at this old thread might be of help – **LINK**
                        #363300
                        Brian Davies 6
                          @briandavies6
                          Hello there , many thanks for all suggestions you really are a friendly helpful gang , I have tried every thing and everything is fine so there is no reason why the auto feed should not work but it doesn’t ,so I will either have to find a service engineer which is proving difficult or just feed manually but as we all know this method leaves a untidy finish ,just a thought tho while I am here ,if I remove the guard that protects the drive travel bar from swathe there is a block that seems to go to the tool head is there any thing inside that block that could have sheared if not I’m stumped of what it could be
                          Thanks again guys
                          #363305
                          richardandtracy
                            @richardandtracy
                            The swarf guard under the saddle only protects the leadscrew from stuff dropping on the leadscrew. The only other thing going around the leadscrew in the vicinity of the saddle is the leadscrew nut, and if it were knackered, then manual drive wouldn't work either.
                            Just wondering.. Is it possible to post a video with the motor running, auto feed engaged and showing all the bits that rotate rotating so we might see for ourselves where the drive stops working? If nothing else, it'd give other owners warning of what might happen & possibly compare with our machines to see what may have gone wrong.
                            Richard.
                            #363307
                              I'm guilty of assuming the lathe had half-nuts! What's the nature of the auto-traverse mechanism on this machine? Gear on a rack presumably but how is drive disconnected for manual mode? Brian asked 'is there any thing inside that block that could have sheared?', I can't even guess.
                              Brian:
                              • I don't know of any roving lathe mechanics who repair hobby machines. Does anyone else?
                              • If everything, especially the feed-screw, is turning as normal the fault must lie inside the saddle, and it might be a small one. Something wrong with whatever it is that links the saddle to the feed-screw – worn-out, bent by an accident, blocked by swarf, or out-of-adjustment.
                              • If auto-traverse isn't vital by all means live without it. But don't be too afraid of dismantling the saddle yourself to have a look; they're not terrifyingly complicated. Like as not someone on the forum can advise.
                              pgk pgk
                                @pgkpgk17461
                                Ditto to Dave's comments.
                                For those new/nervous about taking things apart then really it's a case of disconnecting power (pull the plug out of the wall) and take lots of pics – they can always be deleted later. Don't be embarrassed about labelling every screw with where it came from and keeping them in little envelopes or marked with sticky tape and even marking screw holes and bits with sharpies. At least then if you get into bother there's always someone around here to try and help and you can reverse the provcess to assemble. Oh, and sweep the floor first 'cos whenever I do something like that there's always that 'ping' as a spring flies out and hides…..magnets on a stick are your friend
                                pgk
                                #363310
                                not done it yet
                                  @notdoneityet
                                  ‘’Gear on a rack presumably but how is drive disconnected for manual mode?’’
                                  It’s not. Manual carriage movement is simply by ‘winding the lead screw’
                                  #363319
                                  Brian G
                                    @briang
                                    You are already a long way to finding the fault Brian
                                    As your machine doesn't have half nuts If the carriage can be fed manually using the handwheel on the right there cannot be anything wrong with the leadscrew or nut (or anything else in the saddle). Therefore the problem should be at the headstock end.
                                    Perhaps the parts list can help you narrow it down further? **LINK** If the gear (part 8 on the "Gear Train" drawing on page 18) rotates when you turn the leadscrew handle whilst the feed is engaged the problem is in the gear train, and if not it is between the leadscrew and the gear.
                                    Another Brian
                                    #363374
                                    Brian Davies 6
                                      @briandavies6
                                      Well I have stripped every thing down as far as I can ,sprayed degreaser every where to clean while striped reassembled and it sort of works I say sort of because it seems to travel slower than it did before even on fast setting
                                      While testing I noticed oil leaking out of sight glass so silly me put a spanner on it and it broke the sight glass does look like a spanner would fit but if broke drill it out and helicoiled it ,seems to work ,checked price of a new lathe £1100 or £700 for a smaller one , my old lathe does not work so if need be I will use the travel on manual
                                      Got there in the end so thanks guys
                                      #363376
                                        Posted by Brian Davies 6 on 22/07/2018 17:04:04:
                                        … it sort of works I say sort of because it seems to travel slower than it did before even on fast setting
                                        Or maybe not Brian! My money is firmly on a broken sheer pin. They don't always fail cleanly. Last time I broke one the broken end caught in the sleeve with just enough friction to turn the lead-screw convincingly. But as soon as it was given any work to do, it slipped. Might explain your 'seems to travel slower than it did before' symptom. It is!
                                        Try moving the saddle to the tailstock end and then, with power on and the saddle traversing, see if you can stop the saddle moving by pushing it backwards. If the sheer pin is broken, the saddle will stop and it may become obvious where the problem is. The sheer-pin is most likely passed through the black collar on the left. I don't know the lathe and there might be more than one. If you can't stop the saddle, smile!
                                        Getting a broken sheer pin out can be a right faff. They're punched out by tapping a rod slightly smaller than the pin with a hammer. The hard part is making sure the hole through the feed-screw is aligned with the holes in the collar and that it really is the pin you're punching rather than accidentally whacking something solid. Once the old pin has moved enough to be sure, the repair is easy. A new pin is easily made from brass.
                                        richardandtracy
                                          @richardandtracy
                                          I am pretty sure that if you follow the suggestions I made at 22.03 yesterday you'll be able to find where the fault is, and possibly save yourself £700.
                                          Richard.
                                          #363416
                                          Brian Davies 6
                                            @briandavies6
                                            Hi , I have now tried everything and tried the motor off leadscrew on and could not turn the wheel , when I run the lathe the screw turns and all the cogs turn ,on saying that I can not get the pin out in collar on leadscrew but will try again tomorrow , off to machine mart tomorrow for a air line see what they say
                                            #363485
                                            Brian Davies 6
                                              @briandavies6
                                              Got the pin out ,separated the lead screw bar from where it was connected to ,nothing broke in there cleaned and reconnected reassembled ,not sure about the dog clutch as I don’t know what or where it is so I will live with it being manual
                                              #363496
                                              Les Jones 1
                                                @lesjones1
                                                In your first post when you say that "you can move the saddle / carriage manualy" do you mean by pushing it or by turning the manual feed handle ? (Item 23 on the picture on page 14 of the manual.) If you don't have the manual you can download it from the Machine mart website. If the leadscrew is turning the the only thing that can prevent the saddle moving is the engagement of the half nut with the leadscrew.
                                                Les.
                                                #363500
                                                Brian Davies 6
                                                  @briandavies6
                                                  I can move the saddle/carriage by using manual feed handle ,I’m at a loss here because there is no reason why it won’t move auto as it should that I can see but I don’t know what I am looking at ,going to see if I can get a service engineer out if possible
                                                  #363528
                                                  Les Jones 1
                                                    @lesjones1
                                                    When auto feed is set to on and the spindle is rotating does the leadscrew and manual feed handle rotate ?
                                                    Les.
                                                    #363529
                                                    Brian Davies 6
                                                      @briandavies6
                                                      When the auto feed is set to on the lead screw and the manual feed handle does rotate but the saddle moves slowly ,if I turn auto feed off and turn the handle myself the saddle moves fast if I turn it fast and slow if I turn handle slow
