Clarke Banksaw motor type?
Home › Forums › General Questions › Clarke Banksaw motor type?
  • #238701
    Chris Denton
      @chrisdenton53037
      Evening, I'm replacing the motor on my Clarke CBS45 bandsaw.
      Is it 2 or 4 pole does anyone know? Will either be 1400 or 2800 rpm.
      Thanks.
      #24542
      Chris Denton
        @chrisdenton53037
        #238706
        Muzzer
          @muzzer
          Mine's in the next county so I can't just go out and take a look but this seems to be relevant.Appears to be 1400 rpm nominal in UK.
          #238841
          Chris Denton
            @chrisdenton53037
            Thanks very much!
            #238843
            MW
              @mw27036
              If it's the same as mine then i think it's roughly 350w single phase metric motor 1400rpm 4 pole, it needs the torque for a metal cutting band saw. Doesn't need to cut very fast.
              One caveat to consider may be the frame size of the motor, which will dictate the shaft size for the pulley and the position of the mounting bolt holes.
              Michael W
              Edited By Michael Walters on 15/05/2016 22:31:41
