Clark CL500m run-out
Home › Forums › Beginners questions › Clark CL500m run-out
Viewing 13 posts - 26 through 38 (of 38 total)
  • #278026
    PaulR
      @paulr
      Posted by Michael-w on 15/01/2017 14:03:15:
      One machine I am very envious of, is the Cromwell lathe s800
      A beauty that but I genuinely get a nauseous feeling every time I see a machine with a chuck key left in it like that. Touch wood I've never had the misfortune to forget one but it would be so easy to press one of those inviting buttons!
      Oops, sorry for going off topic.
      #278029
      Allan B
        @allanb
        At work we have a hole in a whiteboard that we leave on purpose, it was made by a chuck key that was left in, and missed someone’s head by about 3 inches, so it’s left as a reminder
        #278034
        Samsaranda
          @samsaranda
          During my time at college many years ago (early 60's) I left a chuck key in on the lathe I was using and started it up, the key flew at great speed the length of the machine shop, fortunately it missed all the other students and collided with the far wall; The instructor gave me a severe verbal lashing and as a consequence I am fanatical about stowing chuck keys away from the chucks even though modern lathes have guards which prevent lathes starting with keys in the lathe. We do learn from mistakes!
          #278038
          Allan B
            @allanb
            I have a thing about the camlocks on the lathes that we use after a story from a good friend of mine, he was serving his time with BAE many moons ago, and on the rotation they had to do 6 months in the machine shop, his first day they had had the basic induction, then left to do a simple task, he turned the lathe on, off came the chuck, rolled the full length of the workshop, strait into the formans office, touched his desk and felt on its side, that was his only day in there and ended up as an aircraft electrician 😂😂
            #287230
            Adrian Adamson
              @adrianadamson34050
              Clarke cl500m
              Could any one with a cl500m help in wiring up the nvr switch as the drawing from Machine Mart is not good.my schematic in the link if any of you could finish it
              Many thanks Adrian
              #287249
                Hello Adrian
                Welcome to the forum
                If you post doesn't get spotted here, I suggest you start a new thread for it.
                richardandtracy
                  @richardandtracy
                  It's too late for me to grab a photo this evening, but I'll see if I can take a photo of mine tomorrow evening and post it Tues morning.
                  Richard.
                  #287391
                  richardandtracy
                    @richardandtracy
                    This from Clarke may help a little in the future (not a lot in this case, though, I admit): **LINK**
                    Richard
                    #287409
                    John Rudd
                      @johnrudd16576
                      Adrian,
                      Can you identify which wires are the start wires on the motor plz?
                      Or conversely which is the run wires……
                      I have a sketch on how to connect all this up, but the motor is the missing piece of the puzzle……
                      Edited By John Rudd on 06/03/2017 11:24:12
                      #287431
                      John Rudd
                        @johnrudd16576
                        Adrian,
                        I've cobbled together a sketch of the wiring, it doesn't include any interlocks that may be present on your machine.cl500.jpg
                        #287582
                        richardandtracy
                          @richardandtracy
                          Posted by richardandtracy on 05/03/2017 18:21:02:
                          Richard.
                          The photo I got, in a windowless un-lit building, by the residual daylight shining through the door at 5.30pm, actually adds nothing to John's wiring diagram above, and possibly confuses the issue as most of the wires are black. So I won't post it.
                          Richard
                          #287589
                          John Rudd
                            @johnrudd16576
                            They say a picture is worth……. 2/6d pence….( I'm pre decimal…)
                            So, I decided I'd do a narrative too……
                            240 v mains enters the nvr relay at terminals 14 and 24. The other side of these contacts, 13 and 23, carry the supply through to the other set of contacts, into terminals 33 and 43. The outgoing side of these terminals 34 and 44 now carry 240 v feeding the Run winding of the motor and also feeds the fwd/Rev switch for the Start winding, entering the switch at terminals 12 and 22. Straps from these terminals go across to 21 and 11 and are crossed over as shown on the drawing, this gives the fwd/rev action and the motor Start winding is connected to the centre terminals, 20 and 10.
                            With no power applied, all the nvr switch contacts are open, applying power and pressing the start button closes the contacts, the coil is energised by power fed from terminals 13 and 23 thus causing the nvr to latch.
                            Removing the power denergises the coil, and opening the contacts. Pressing the stop button opens the contacts and de-energises the coil.
                            Some would say the second set of contacts is superfluous, but it provides added safe guard from stuck contacts….
                            I think thats right?…….enlightened I aint no enjineer….
                            Edited By John Rudd on 07/03/2017 16:30:50
                            Edited By John Rudd on 07/03/2017 16:31:37
                            #287758
                            Adrian Adamson
                              @adrianadamson34050
                              Thanks for the replies, will try this out.
                              Cheers, Adrian.
