Posted by Ernie Smith 1 on 31/12/2017 12:25:26:
Hi, I usually subscribe to the RCM&E model aeroplane forum, but have a wee problem that you guys might help me solve
I'm setting up a clarke CL300 lathe, and have a problem with the apron. The manual saddle feed gears are not a close fit to the teeth under the bed, so there is a lot of slop. I guess the gears could be raised by quite a few mm, and I can't see any way of adjusting this.
Now, it's very possible that I'm missing something obvious because I'm something of a turning neophite
thanks ernie
Hi Ernie,
A Clarke CL300 is a 'C2 SIEG mini-lathe'
The issue you are referring to is probably relating to 'the fit' or alignment of the rack under the bed, and/or the longitudinal leadscrew. Have a look at this dismantling guide for the C3 lathe (not SC3). A Clarke CL300/C2 is broadly speaking a shorter bed version of the old C3 lathe.
I would suggest you first read through this picture guide.
In particular, for the rack, pay attention to points 84 to 88. when you remove the rack, look out for swarf/cast iron dust resulting from original drilling/tapping of holes during assembly, which could have distorted the alignment of the rack.
For the saddle assembly, leadscrew and related brackets, pay particular attention to points 100 through to 120.
Ketan at ARC.
Edited By Ketan Swali on 03/01/2018 15:51:10
