Posted by old mart on 10/08/2021 15:36:11:
There will be a joint between the base and the top half, this is where the 3/16" would be best removed from. This would be easy if a mill was available. The alternative might be to mount the base on a faceplate, square up the surface and turn off the surplace.
The tailstock of the museum Smart & Brown has shims between the halves to get the height and direction of the quill on the centre line. Actually it is set 0.001" high on purpose. I ought to set it up and mill it to take a decent thickness shim, but I'm too lazy.
On the other side of the pond, The Home Shop Machinist forum is well worth joining.
This.
I fitted a QR tailstock to my mini lathe, as I recall JS gave it to me as it was a leftover from converting one for specialist CNC that didn't require it. The advantage chiefly being it was easier to adjust than my homemade QR.
Coming from a different batch (maybe 15+ years younger?) it was slightly high – better than being low! As I recall, I took a bit too much off the baseplate but as the difference in height was in the upper part, I was able to be a bit more careful and thin down my original baseplate to leave me with a hybrid tailstock.
There are some arguments for getting the tailstock about 0-.001"/0.02mm high. What is important is making sure it is level so it doesn't rise/droop when extending it.
