Posted by John Haine on 07/04/2018 16:06:28:
John Stevenson used to point out that usually it's the end teeth of our cutters, and the first mm or so of the flute, that get blunt, and encouraging people to use more of the edge they had paid for. So except for reconditioning industrial cutters flute sharpening maybe isn't so useful?
I can recommend the Acute system to hold and index cutters for the end teeth. Could probably be retrofitted to your Clarkson.
Cheers John, but I have a number of older second hand end mills that have blunt flutes, which would be handy to use occasionally.
I'm set up OK for end teeth, as I made a quick lash-up gizmo when I first got the Clarkson, originally using a drum brake hydraulic slave cylinder to provide the bore to run the collets in. This was in turn mounted on a bit of 3" square angle iron to provide a tilt and swivel facility. The casting helpfully had a round machined boss in between the two backplate mounting studs, so I just needed a hole of suitable size boring the the upright of the angle, and a couple of curved concentric slots for the two studs.
It's now been superseded by an adapted J&S universal head, which I came across broken in a pile of other bits from ebay.
I still need to make a longer sliding sub table for my planer-thicknesser blades, as they are 8", but there's only 6" throw on the Clarkson. I've got a load of heavy duty ball drawer sliders, which on their own rock too much, but as a parallel pair, with a little bit of tension between them, should to the job fine for woodworking machinery.
Bill
