cheap digital vernier calipers.
Home Forums Workshop Tools and Tooling cheap digital vernier calipers.
Viewing 25 posts - 26 through 50 (of 67 total)
  • #266414
      Posted by Neil Wyatt on 13/11/2016 19:18:06:
      A wise man once wrote:
      Which 'wise' man would that be, Neil ?
      … and who, round here, would want to 'stay out of meaningless arguments' ?
      Edited By Michael Gilligan on 13/11/2016 19:41:15
        Definition 1.1 should fuel the debate …
        https://en.oxforddictionaries.com/definition/caliper
        devil … So much for the O.E.D.
        Contrariwise, I have an old booklet from Brown & Sharp,
        entitled 'Principle of the Micrometer Caliper'
        Edited By Michael Gilligan on 13/11/2016 19:53:26
        #266430
          Posted by Michael Gilligan on 13/11/2016 19:49:31:
          Which reminds me… I emailed them last week suggesting they add 'noggle' to the OED
          N.
          #267384
          ALAN CANTWELL
            @alancantwell54065
            Before you all get lost in an english debate, we call them simply digital vernier calipers, An interesting note is, we bought one of the £10 cheapies from Aldi a while ago, now, all our gear has to pass calibration, twice a year, we put this poor little caliper through hell, it passed wirh flying colours on all scales, we use mitoyotos, i have 2 at work, and 1 failed calibration one at home, 18 month on, the Aldi cheapy is still going strong, measuring sawn off billets in the saw shop, but, we cannot use it on machining, as 1st article inspection reports have to state make and model of measuring gear, wouldnt do, would it, to see Aldi caliper on the report, lol ! Only thing we have found is the linear slides are way inferior, But for a tenner? Surprised us!
            #267394
              Posted by ALAN CANTWELL on 19/11/2016 19:00:15:
              … we call them simply digital vernier calipers …
              I guess that must be 'definitive' then.
              devil MichaelG.
              #267401
              Chris Evans 6
                @chrisevans6
                I have three Aldi digital callipers, one has been in everyday use (OK three or four days a week now Iv'e retired) no problems with reliability or accuracy. The other two are going to be butchered as read outs on the lathe tailstock and Bridgeport quill. I have made a start on the tailstock one and thing look promising.
                #267417
                  In my test the Aldi one was accurate enough, but if it warms or cools the reading drifts, and by a lot, so you have to zero it regularly.
                  #267424
                  ALAN CANTWELL
                    @alancantwell54065
                    That would be the inferior linear slides, lifting off the tracking, it loses its voltage, tighten up the two linear guide screws on the top if it has them, could you have not returned it? My mitoyo that was rejected suffered this, after only 18 months use, in a working enviroment, i got another for half price, Thing is, since its been at home, its been faultless, go figure, the tragedy of using electronic gear, is the guys do not know how to read non digital, another nail in the skills coffin,
                    Edited By ALAN CANTWELL on 19/11/2016 23:07:11
                    #267426
                    Rik Shaw
                      @rikshaw
                      I bought and still have an 8" "clockwork" Mitutoyo VC which cost me plenty from the tool club at my work place circa 1970's. It sits in my study desk drawer and is used rarely and only when nostalgia beckons.
                      However, I also have an ALDI digital economy job which I use every day simply because I do not need a magnifying glass to read it. Even so, I never rely on either of these instruments for "tolerance" work. I find that a micrometer gives a far more positive reading. Still though, I find both instruments very handy especially for measuring shallow bores compared to using a combination of internal calliper/micrometer.
                      Rik
                      #267428
                      ALAN CANTWELL
                        @alancantwell54065
                        You are correct sir, the caliper is used on open limit lengths, micrometers are used for all diam measurment, including internal bowers types, plus plug gauges for bores, the caliper can be quite usefull for depths with open limits stuff, but we never use a caliper for anything under .1 mm tolerance, for this is what they are rated at, .1 mm accuracy,
                        #267429
                        Hopper
                          @hopper
                          Posted by Neil Wyatt on 13/11/2016 19:19:08:
                          Of course the productive ground for argument is calliper or caliper?
                          The OED lists both…
                          Occam's Razor would lead us to use caliper.
                          What do you guys call the original mechanical vernier caliper with the visible lines to be read? I have always heard them referred to simply as a "vernier". Such as "Pass me that vernier, would ya" and "Where did that bloody vernier go?" Hence if the mechanical calipers are commonly called a vernier, it makes sense that when you add a digital readout to the tool it becomes a "digital vernier".
                          Nobody I know ever referred to the original mechanical vernier calipers as simply "calipers". If someone asks you to pass the caliper, they want the type with two legs and a spring loaded pivot in the middle. I have never seen a digital one of them, yet.
                          #267432
                          ALAN CANTWELL
                            @alancantwell54065
                            Refer to them as vernier, plain and simple, i still use one, its 5 foot long, Only me alone uses it,
                            #267434
                            ALAN CANTWELL
                              @alancantwell54065
                              Oh, and no-one uses the old vernier, all scrapped long ago when digital appeared, same with mics, the ratchet is so good,  demonstrated tgat 10 guys micing up a job got the exact same reading to 1 micron, thats pretty damned good for our line of work, which is ultra high prescion, all mics and verniers are mitoyoto, superb equipment,
                              Edited By ALAN CANTWELL on 19/11/2016 23:38:31
                              #267439
                              Enough!
                                @enough
                                Posted by Hopper on 19/11/2016 23:28:58:
                                Strictly, the caliper is the body of the device and the "vernier" is the sub-scale used to finely divide (interpolate) the readings on the main scale (you can have verniers on lots of other measuring equipment too – including micrometers and other devices not associated with machining).
                                – without this sub-scale, the device is a caliper
                                – with the sub-scale it's a vernier caliper (often colloquially – and loosely – called a "vernier" for short)
                                – without the sub-scale but with a digital interpolation device, it's a digital caliper.
                                – "digital vernier caliper" is an oxymoron used by people who don't know any better.
                                Edited By Bandersnatch on 20/11/2016 02:01:11
                                #267440
                                Hopper
                                  @hopper
                                  Posted by Bandersnatch on 20/11/2016 01:57:18:…
                                  …(often colloquially – and loosely – called a "vernier" for short)
                                  Hence when you add a digital readout to it, it is colloquially – and quite legitimately – called a digital vernier.
                                  Colloquialisms are how language progresses. Without them we would still be talking in monosyllabic grunts. Most words in the OED today started life as colloquialisms.
                                  #267441
                                  Enough!
                                    @enough
                                    A masterpiece of non-sequiteur …ism.
                                    no
                                    Edited By Bandersnatch on 20/11/2016 03:51:23
                                    #267444
                                    Hopper
                                      @hopper
                                      Non-sequiteurism, is that a word?
                                      #267445
                                      Danny M2Z
                                        @dannym2z
                                        No batteries, no Vernier – maybe just the ideal present.
                                        These are almost 40 years old and my #1goto before the micrometer leaves it's case.
                                        #267449
                                        Speedy Builder5
                                          @speedybuilder5
                                          Yes, same for me although a cheaper version. Its a pity that they don't have a way of making them read both imperial and metric though. It would need some sort of reduction gear in the dial which could be selected in or out I suppose.
                                          BobH
                                          #267450
                                            A quick summary:
                                            Caliper [or Calliper] describes a mechanical structure, and, in the current context that is something 'portable' with a pair of parallel jaws; one 'fixed' and one 'sliding'.
                                            Vernier; Dial; Digital; Micrometer, Remote, etc. are all types of measuring and/or display system; any of which can be applied to the basic caliper.
                                            … It only becomes difficult when colloquial usage distorts the meaning.
                                              Posted by naughtyboy on 12/11/2016 14:01:30:
                                              my 7 yr old girl as put measurer like daddies on xmas list.
                                              blush We keep straying from the original point ^^^
                                              What does the young lady actually want ?
                                              … is it the caliper, or the digital display that matters to her ?
                                              … or [most likely] that it is "like daddies"
                                                Posted by Michael Gilligan on 20/11/2016 08:04:09:
                                                You mean it resembles a group of fathers?
                                                Or did you mean "daddy's"?
                                                devil
                                                Pedants'R'Us
                                                #267475
                                                  Neil … That's why I very deliberately put the phrase within quotation marks.
                                                  I didn't think it would be appropriate to correct the original text.
                                                  [ You, as Editor and Moderator, obviously play by different rules.]
                                                  Circlip
                                                    @circlip
                                                    And for the pendantics, a spulling test next?? and something about a Panda shooting leaves?
                                                    Regards Ian.
                                                    #267494
                                                      Posted by Michael Gilligan on 20/11/2016 10:16:26:
                                                      I hadn't realised it was a quote and wouldn't have prodded anyone else, but as our resident spotter of unintentional meanings in my postings, I consider you fair game
