Cheap but decent Mini Tape Measure
Home Forums Workshop Tools and Tooling Cheap but decent Mini Tape Measure
Viewing 22 posts - 126 through 147 (of 147 total)
  • #277410
    Harry Wilkes
      @harrywilkes58467
      Posted by Flying Fifer on 12/01/2017 18:56:21:
      Or use a bit of string !!!
      Yes but how long is a piece of string ?
        Posted by Neil Wyatt on 12/01/2017 21:15:13:
        I'm just eyeing my tape measure suspiciously …
        Wow … on the seventh page, he drags the thread back onto topic [ish]
        Another JohnS
          @anotherjohns
          Posted by Harry Wilkes on 12/01/2017 21:20:17:
          Nooo!!! No String Theory, please!
          (for those who are not familiar with "String Theory", google it…)
          JohnS.
          #277425
          Dod
            @dod
            All them protons flying around in a vacuum in Trafalgar Square with excited Caesium at the speed of light is a bit of overkill to measure how thick a short lump of wood is to see if it is actually a plank. indecision
            #277591
            John Flack
              @johnflack59079
              This may be a tad theoretical but what would the speed of light if you lived on the sun?????????????
              #277596
              Ajohnw
                @ajohnw51620
                I was idly wondering about something the other day – just in case. Say I have this motor with a certain power doing some rpm or the other fully loaded and I wanted to work out the torque in terms of force via it's feet on the plate it's mounted on.
                devilThanks to this thread I was wondering if I would do the sums in metric or imperial.
                Edited By Ajohnw on 13/01/2017 20:13:19
                #277597
                Mike Poole
                  @mikepoole82104
                  I think the speed of light is a constant, sitting on the sun could be a bit on the warm side but my wife would probably be cold.
                  #277602
                  JimmieS
                    @jimmies
                    Back to the mm v cm discussion. Called into a Polish dressmaker to get trouser's legs shortened by 5 and a half cm. "Sorry" she replied reaching for her tape. "could you show me?" I pointed at 5.5 CM and she replied " you mean 2 1/4 inches."
                    I think I will give up trying to make life easier for other folk!
                    #277611
                    Allan B
                      @allanb
                      I was with a student the other day, and I asked him to set a vernier height gauge to 25mm, left him to it, and returned a few min later, and instantly I knew it was wrong, way too high, and it went as such….
                      Me "are you sure that is right?"
                      student "yes"
                      Me "can you explain how you came to set it to that height?"
                      student "well 25mm is 2.5cm so I set it to 2.5cm"
                      me "can you show me on the scale where 2.5cm is?"
                      student points to 2.5 inches disgust
                      I will just leave that one there
                      #277612
                      JimmieS
                        @jimmies
                        Allan, remember the old saying ' a teacher never retires early – it is always too late'. Wonder why?
                        #277672
                        John Flack
                          @johnflack59079
                          Joking aside I am having sleepless nights regarding the speed of light . Is it a universal constant or would it be different on each planetary surface. My model is that the sun is like a cannon firing electro magnetic waves across the universe. My thoughts are that the initial burst of energy is at a higher speed than the trajectory which follows and the speed of the waves will slow over a distance as the energy dissipates to zero, this suggests that the speed of light is variable and that it will be no more than an average speed when calculated over a fixed distance. Is my thinking flawed???????
                          #277679
                          Allan B
                            @allanb
                            Posted by John Flack on 14/01/2017 11:02:17:
                            you are correct in your thinking from what I can remember as to how it is generated, and if it is generated in an atmosphere then your thinking on the slowing down would be correct as there is other apects to be taken into consideration, but as the sun and other sun's actually sit in a vacume then there is nothing else to act on the engery waveform on its travels so it stays at a constant velocity.
                            but I will stand corrected on this if someone has any other thoughts
                            Allan
                            #277680
                            Allan B
                              @allanb
                              Posted by JimmieS on 13/01/2017 21:17:25:
                              yes I know that saying, and it is never more in my thoughts than at the moment thinking
                              #277682
                              Tim Stevens
                                @timstevens64731
                                John asks if his thinking is flawed.
                                Yes, John, I am afraid it is. At least, the science on which you rely is flawed, and so the thinking which follows cannot be correct. Light is not affected by air resistance or any similar effect, it does not use up its energy as it whizzes along. It is affected very slightly by gravity (which does seem to contradict the universality of its motion) but I think the speed remains the same. What alters with gravity is the velocity, which in science terms combines speed and direction.
                                And in a black hole there is so much gravity that the light cannot escape, but in such places the ideas of time, direction, etc go all peculiar, too.
                                I think.
                                Regards, Tim
                                #277695
                                  Posted by Tim Stevens on 14/01/2017 11:39:35:
                                  To develop that thought a little …
                                  The speed of light in vacuo is [by mainstream dogma] asserted to be a fundamental constant.
                                  but that is the fastest that light can go; and it is demonstrably slowed-down by passing through various media [which is, of course, the foundation of refractive optics].
                                  http://www.physicsclassroom.com/class/refrn/Lesson-1/Optical-Density-and-Light-Speed
                                  Edited By Michael Gilligan on 14/01/2017 12:51:59
                                  #277697
                                  Keith Rogers 2
                                    @keithrogers2
                                    Amazing how this thread has gone from the humble tape measure to the discussion of the speed of light.
                                    That's forums for you laugh
                                    Keith.
                                    #277702
                                    Geoff Theasby
                                      @geofftheasby
                                      Check out Cerenkov Radiation.
                                      Geoff
                                      #277707
                                        Posted by Geoff Theasby on 14/01/2017 13:43:53:
                                        Geoff
                                        … and my recent posting on the 'beauty of tools' thread angel
                                        John Flack
                                          @johnflack59079
                                          Checked out Cherenkov radiation……. Gives you a headache. Simple question is the term 'space' the same as 'vacuum' I find the concept of a vacuum containing a universe contradictory!
                                          #277772
                                          pgk pgk
                                            @pgkpgk17461
                                            Posted by John Flack on 14/01/2017 19:28:05:
                                            'course not.. lots of stuff in space and doubtless someone will have average particles per metre^3 or Km^3.. why the lensman with his bergenholm (inertialess condition) could only travel at the speed in which the power of his propulsion equated to the density of matter which fortunately was a lot lower intergalactically than intragalactically
                                            #277789
                                            Geoff Theasby
                                              @geofftheasby
                                              John,
                                              Not really headachey, Particles, which travel at the speed of light, emitted by radioactive materials underwater, are slowed by the Moderator (Water) The speed of light in water is lower, so according to Newtonian physics the absorbed energy is emitted as blue light.
                                              Geoff
                                              #278397
                                              Ajohnw
                                                @ajohnw51620
                                                My truly small pocket tape arrived this morning.
                                                It does seem to be well made so in my view worth the price. The spring return is so fast it could probably be used as a weapon. It might even cut a finger.
                                                Weight 35g and none iso surprise as it's marked in mm and cm as most do with the 10's in red. Nice clear scale as well.
                                                Thanks to brexit the price has now gone up by 24p since I bought it on the 5th. Pity I didn't find them last time I looked, well over 12 months ago.
                                                I asked at a shop why I couldn't buy a quality really small tape. Guess it's down to price but while it's rather steep providing it lasts I don't mind that.
                                                Edited By Ajohnw on 17/01/2017 11:30:44
