casting identification
Home › Forums › Help and Assistance! (Offered or Wanted) › casting identification
  • #544225
    The home engineer
      @thehomeengineer
      Hi All
      I would be very grateful for someone could help identify the castings in the photos. I have been clearing a friends workshop and came across these casting in a box and would really like to know what they are for.
      I thank all in advance for taking a look
      Andy
      #33829
      The home engineer
        @thehomeengineer
        #544234
        Nigel Graham 2
          @nigelgraham2
          A rule or familiar object for scale would help, if you can supply – of at least give us the basic measurements.
          The larger casting appears to include bearing journals and suggests the headstock for a small lathe. It looks as if the owner had just started to machine it.
          The smaller one could be almost anything though a pipe-fitting manifold comes to mind.
          Any clues from your friend's main engineering line? Any drawings about? (He may have kept them in the house.)
          #544278
          not done it yet
            @notdoneityet
            Tool & cutter grinder kit?
            #544294
            bernard towers
              @bernardtowers37738
              Might pay you to ask Kirk from Hemingway he has lots of info on castings
              #544977
              The home engineer
                @thehomeengineer
                "A rule or familiar object for scale would help, if you can supply – of at least give us the basic measurements."
                Hi The large casting basic dimensions are 3" in all directions, large boss 1" diameter with 7/8" gap one is 7/8" long the other1"1/4. The gap is 1"5/8 between the lugs.
                The small casting is 5/8" diameter 2" long with 4 off 3/8" bosses.
                My friend was a keen clock man but also made many tools for the Myford ML7 lathe.
                Thank you all again for any further help
                Andy
                Edited By The home engineer on 14/05/2021 12:46:06
                #545054
                Bazyle
                  @bazyle
                  They might have nothing to do with model making activities. The larger casting could easily be part of a loom or other industrial machine that was picked up by some factory or foundry hand because it looked like it might be made into something at home.
