Cast iron / metal suppliers
Home › Forums › General Questions › Cast iron / metal suppliers
  • #261138
    John Lintorn
      @johnlintorn87585
      Has anyone got any good suppliers of cast iron? I ideally need 3 5″ square mild steel and a 3″ cast iron billet for cylinders. Any ideas chaps?
      #24802
      John Lintorn
        @johnlintorn87585
        #261141
        Anonymous
          I use M-Machine Metals for cast iron sections. As yet I've only bought rounds up to 130mm diameter, with no problems. The supplied cast iron machines beautifully.
          #261156
          KWIL
            @kwil
            College Engineering Supplies, not the cheapest but a wide range. Cut to size available.
            #261161
            Mark P.
              @markp
              Try your local engineering shop, I recently got a 3″wide x 8″ diameter chunk from mine less than ?50.
              Mark P.
              #261172
              Iain Downs
                @iaindowns78295
                I recently (last week) bought 3 x 1 inch lengths of 4 inch diameter cast iron from South West Steam Miniture Engineering for 5 pounds each plus 5 pounds for carriage.
                The price per inch was quite a bit lower than the usual suspects and the carriage also reasonable.
                I made the purchase through ebay but I daresay they take orders direct. I had some questions and got them answered promptly (e.g. if I ordered 3 inches could I have 3 one inches and not one 3 inch…).
                I'm planing to scrape a Whitworth plate when time permits. Back with results in 2018…..
                Iain
                #261174
                  Can't add much as I have used all three of the suggested suppliers. South West even supplied me with a longer length rather than cut to what I ordered at no extra cost to save them having to cut it. College I usually pick up at a show if I can.
                  #261175
                  Chris Evans 6
                    @chrisevans6
                    This year I have made patterns for a lathe cross slide and various other parts and had them cast at a foundry at more than reasonable prices. I have also had aluminium castings made at a different foundry also very cost effective. An advantage of being based in the Midlands !
