Can a Drill be a Mill?
Home › Forums › General Questions › Can a Drill be a Mill?
  • #256003
    daveb
      @daveb17630
      Some South Bend drilling machines were advertised as being suitable for light milling. Accessory spindles were available to hold milling cutters. The spindle could be changed by removing the name plate and slackening a screw. Dave
      #256012
      Raymond Anderson
        @raymondanderson34407
        I'ts a sure way to ruin a drill press. Drill press spindles are not designed to cope with the large radial loads that milling generates, simple as that ! X Y tables when fitted to drill press tables are fine for coordinate drilling of holes. The spindle bearings wouldn't cope with anything but the lightest of milling. There is a big difference in the bearings of a milling machine and those in a drill press. At the end of the day it's your drill press.
        #256019
        Bob Abell 2
          @bobabell2
          That's why I suggested an outrigger bearing assembly
          Bob
          #256049
          NJH
            @njh
            My take :- Pillar drills are good for drilling , Mill / Drills are good for milling AND drilling. I have both – that is mainly for the convenience of having the ability to drill a hole without disturbing a set-up on the mill. As has been previously posted it is dangerous to make intermittent milling cuts on a drill in case the taper on the chuck is released – you can imagine the likely consequences of that! The milling chuck, containing the cutter in a collet, is securely retained in the spindle by a drawbar. All this aside the Mill/drill is a much beefier machine than the usual drilling machine.
            Norman
