Oops, forgot to add to this.
Metal ordered and delivered – very impressed with the service from Macc Models and Chronos – delivery to Ellon within 2 working days.
I decided to stick with David Fenners book, The Mini Lathe and have started to build the dividing head he described.
The only problem I faced was deciding which cutting tool was which – it wasn’t totally obvious to a raw beginner like myself. Searching the web was the best solution.
Must buy a work coat since I’ve ruined one shirt already. Luckily it was an old one.
Turning seems to be very therapeutic. I now have half a bucket of oily steel wool! Anyone ever found a use for it?
I borrowed a 16 mm drill for the body of the device and used this insted of the 17 mm drill specified – shouldn’t matter. Turned the taper slightly longer to compensate. The taper plug which I then turned actually fitted!
Using the lathe to ensure that taps and dies are square makes life much easier. Wish I’d got one before!
Tried some brass this evening – nice not to be using oil but the brass shards fairly manage to stick to the layer of oil from before – messy!
Used the knurling tool for the first time. Next time I will use it before I part it from the bar I was working on. It was then left too small for the knurling tool to get past the chuck. Instant result in use though. SWMBO wasn’t impressed.
Nasty job for tomorrow – cutting 3mm steel plate to size and shape without a band saw.
Bob
