Bridgeport TEE nut size ?
Home › Forums › Beginners questions › Bridgeport TEE nut size ?
  • #6225
    Dave C
      @davec87625
      #93839
      Dave C
        @davec87625
        I have been lucky enough to find a superb condition Bridgeport with varispeed head. It is being delivered next week. Still cant quite believe it ! however, I want to make some tee nuts so that I can get things moving straight away when it arrives.
        I have found lots of information all over the web but as regards tee slot size, All I have found is 16mm.
        What would be the other dimensions of the Tee nuts need to be please.
        Thanks in advance
        Dave C
        #93840
        Dave C
          @davec87625
          Please excuse the bad english. The excitement must be getting to me.
          What would be the required dimensions of the Tee nuts please.
          Dave C
          #93841
          Sub Mandrel
            @submandrel
            You need a hot cup of sweet tea.
            KWIL
              @kwil
              Slots on a Bridgeport are 5/8" they are Imperial, T nut is 0.613" high, 0.990" wide, 0.600" on the stem, 0.325" high on head of T, hope that is all clear, 1.05mm high, 25mm wide, 15.5mm stem, 8.3mm head of T.   27.5mm long, 1.080" long. That should cover it.
              Edited By KWIL on 06/07/2012 20:08:14
              #93846
              Dave C
                @davec87625
                Thanks KWIL
                Much appreciated
                Dave C
