Hi
You may have seen this already :
Brass
If you look at the ‘knowledge base’ here you will find a lot of information but it does not necessarly translate into the terms you require. Worth a read all the same.
CZ120 is engraving grade brass and is ‘half hard’ – in other words it’s a bit easier to file. It has a lead content, about 3 percent or so.
CZ108 is not quite as soft and is also known as ‘common brass’ or ‘yellow brass’. It has no lead so a bit harder to work but is a good colour.
There are other ‘grades’ with names such as jewellers brass, cartridge brass, guilding metal etc. but they are all just variations in the proportions of copper to zinc giving different properties.
I would say that if otherwise unspecified, CZ108, common brass is what you need. You may also see it referred to as CuZn37 or ISO-C2720. It’s all the same stuff.
Anyone else please feel free to correct me / add to this.
Diane (back street metallurgist ‘n-all)
Edited By Diane Carney on 25/11/2011 12:34:10
