Boxford STS 10 30 weights
Home Forums Manual machine tools Boxford STS 10 30 weights
  • #352185
    PutneyChap
      @putneychap
      Getting one of these on a cabinet. Anyone got the weights? – preferably with the cabinet separated. I am going to take the tailstock off – and, may wind the carriage off as well, plus take the motor off. Hoping that will bring it down to 200kg – which is manageable for me. – its the long bed model – but if anyone has the standard bed weight – that would be good – there won't be too much difference.
      PutneyChap
        @putneychap
        #352192
          Think they are about 400kg all up so you may not get it down to 200Kg
          #352203
          David Standing 1
            @davidstanding1
            As Jason says, somewhere between 350 and 400kg, depending if yours is the 750mm b/c model, or 1,000mm.
            And if you split the lathe and cabinet, be warned the lathe becomes incredibly top heavy, and if lifted will try and flip itself over.
            I have had three X10 series Boxfords, currently a 330, and the way I move them is to keep them in one piece, and put them on four heavy duty castors.
            I can push one around single handed on a concrete floor when it is on castors.
