The world of model and hobby engineering
Forums
Help
Register
Log in
Home › Forums › Manual machine tools › Boxford change wheel – bore size?
Hi
Can anyone please advise me what the bore size is on change wheels for the Boxford lathes? I know they are 18dp and I assume 14.5deg.pa, but I can't find the hole size anywhere.
Thank you
Keith
Hi Keith,
Just measured mine and the gear bore is 9/16 inch.
Many thanks for that – as far as I'm concerned that's the perfect size – means I can fit them to my lathe which is something totally different!
Keith, you are also correct to assume a pa of 14.5 degrees for the changewheels, though some fixed gearing in later models was changed to 20 deg.
Thank you for confirming the pa, that really is one of the specifications that's difficult to check – especially by just a visual inspection.
Started by: glynboy12 in: Beginners questions
noel shelley
Started by: dk0 in: Clocks and Scientific Instruments
dk0
Started by: jjkfj390v in: Introduce Yourself – New members start here!
Started by: JimmieS in: The Tea Room
Started by: Vic in: Materials
Vic
Started by: JasonB in: Miscellaneous models
Diogenes
Started by: Vic in: The Tea Room
Bazyle
Started by: Phil Whitley in: The Tea Room
Phil Whitley
Started by: Michael Gilligan in: General Questions
bernard towers
Started by: Richard Simpson in: Related Hobbies including Vehicle Restoration
Richard Simpson
Started by: dean clarke 2 in: I/C Engines
Started by: Greensands in: The Tea Room
Started by: JasonB in: Materials
Started by: Byron Williams in: Introduce Yourself – New members start here!
Started by: jim1978 in: Introduce Yourself – New members start here!
Started by: daves 1 in: Introduce Yourself – New members start here!
zach
Started by: Michael Gilligan in: The Tea Room
Nicholas Farr
Started by: Steve Huckins in: General Questions
Started by: stew 1 in: The Tea Room
Oldiron
Started by: JasonB in: The Tea Room
Dalboy
Started by: ell81 in: Books
densleigh
Started by: Bazyle in: Exhibitions, Shows and Club Events
Started by: Bo’sun in: Workshop Tools and Tooling
cogdobbler
Started by: Michael Callaghan in: Manual machine tools
samuel heywood
Started by: gerry madden in: General Questions
