Boxford CBS screw cutting charts
Home Forums General Questions Boxford CBS screw cutting charts
  • #354342
    Stephen Fulcher
      @stephenfulcher36121
      Hi all, I am hopping for some help. I bought a boxford CBS lathe last year and have been learning the basics in my workshop. Now that I am finding my way around it I would like to step it up a little. My lathe does not have a screw cutting on it, I was hopping that some one out there may be able to point me in the right direction or even have the same lathe with the charts I need?
      Thanks in advance.
      Steve
      Stephen Fulcher
        #354356
        RichardS
          @richards31161
          Hi Stephen
          Do you mean a Boxford CSB? If so then the necessary info is available in the Files section of the Boxford Lathe Yahoo group (you will need to join the group and yes, I know the user interface is very poor). However, you say there is no screw-cutting on the lathe. Does it have a leadscrew? If not then what you have is a training lathe and adding screw-cutting means finding, at minimum, a leadscrew with bearings, quadrant, an apron, tumbler set and changewheels.
          This website will help with identification http://www.lathes.co.uk/boxford/
          Richard
          #354358
          Stephen Fulcher
            Hi Richard
            Yes I Ment csb, it has a leand screw and I have all the change wheels. I would just like A copy of the screw cutting chart
            #354359
            David Standing 1
              @davidstanding1
              Whilst assumption is a dangerous thing, and not somewhere I normally go; I suspect the original post was missing the key word 'chart' between 'cutting' and 'on'.
              #354361
              David Standing 1
                @davidstanding1
                Aha! Stephen was posting as I was typing!
                #354362
                Stephen Fulcher
                  It’s was! My mistake
                  #354368
                  RichardS
                    @richards31161
                    Try this thread
                    http://www.model-engineer.co.uk/forums/postings.asp?th=124071
                    Posting by Robbo at 19/01/2017 23:24:07
                    Titled: Boxford Model B&C Lathes
                    Also can be found in the Boxford “know your lathe” book.
                    Richard
