Boiler Ferrules – Whats the correct material to use?
Home Forums Beginners questions Boiler Ferrules – Whats the correct material to use?
  • #6071
    Steve Withnell
      @stevewithnell34426
      #88503
      Steve Withnell
        @stevewithnell34426
        I have a Stuart 504 boiler and I need to replace a couple of the ferrules – easy enough to make, but what is the correct material to use?
        Thanks
        steve
        #88517
          What are you meaning by Ferrules? do you mean the bushes that are soldered into the boiler to take fittings if so use bronze.
          If its the ferrule that goes on the end of a pipe again I would use bronze as its a bit softer and will take up any irregularity in the joint though brass is quite common.
          J
          #88525
          Steve Withnell
            @stevewithnell34426
            Yep it's the component that' soldered into the boiler, threaded to take the various fittings.
            Thanks Jason
