Best way to cut stock to size
Home › Forums › Beginners questions › Best way to cut stock to size
Viewing 25 posts - 1 through 25 (of 62 total)
  • #272730
    Men Ifr
      @menifr84251
      Say I have some angle iron I want to cut and it’s 3 to 4 mm thick by 40mm and 2m long.
      I need to cut 200mm off then cut along one side (200mm cut)
      I’m getting a bit fed up of doing this with a hacksaw I don’t do loads but it’s hard going..
      I’m wondering if I should invest in a chop saw I can get one from screwfix for £80 or £90? Though that seems to use an abrasive blade.. Or would the money be better spent (and save precious garage space) getting a cutting arbour? But that can’t cut the length.
      I could mill a slot the whole way through the 200mm length but expect that will be a slow process if I’m using a small cutter and.
      #8449
      Men Ifr
        @menifr84251
        #272733
        Ian Parkin
          @ianparkin39383
          Cheap way is a 4.5 inch angle grinder with a 1mm blade in …will slice through in no time
          The cheap chinese 4×6 bandsaws will also do it easily
          #272745
          Brian G
            @briang
            My son has one of the cheap "Evolution" chop saws from Screwfix (very cheap – 110V in their sale was half price) with a TCT blade that will cut timber as well as metal (although remember to remove any sawdust from the bag before cutting steel). Works OK although the clamping seems to have been designed for partitioning etc. so it doesn't hold smaller materials or round bar that well – making a vice for it is on the "to do" list.
            #272746
            Frances IoM
              @francesiom58905
              put the money towards a small bandsaw eg the cheapie from Chester tools saves hours – however a small angle grinder in a fixed stand (Aldi do a very cheap stand + small grinder at times = no doubt others do as well) use the very thin cut off blades – gets thru upto about 25mm stainless which would gag the bandsaw + cut off saw
              #272764
              Nigel McBurney 1
                @nigelmcburney1
                Angle grinder,with a 1mm disc, it also has lots of other uses e.g. wire brush,grinding discs,sanding discs etc, apart from cutting the angle iron all the burrs and sharp edges can be removed with a heavy grit sanding disc,or rust removed with a wire wheel, I have half a dozen angle grinders it saves time by not having to change the discs,wire brushes. etcI have a power hacksaw,large industrial bandsaw ,mill etc ,but it is surprising how often I use an angle grinder,buying cheapie saws is not recommended they are really not up to the job.
                #272767
                Russ B
                  @russb
                  I have a blackgates power hacksaw but a 1mm cutting disk in the angle grinder is my weapon of choice for steel – it will melt through 3-4mm thick angle like butter, gentle pressure only.
                  The hacksaw is great, fits on my bench top and stowes out of the way, but its a steady job – 10 minutes for your average cut through a solid bar or angle. just about the right amount of time to go and do something else. The longest and biggest cut I've ever done, was a 60mm solid round EN16 shaft (times 10!) each cut was around 50 minutes with gentle pressure (weights on the handle) – I wouldn't image a single 1mm cutting disk would get through that
                  #272768
                  Circlip
                    @circlip
                    Would have thought it would have been more economical on material and effort to buy Flat of 4mm thickness by whatever width.
                    Regards Ian.
                    #272769
                    MW
                      @mw27036
                      Posted by Ian Parkin on 19/12/2016 11:09:44:
                      Agreed, a slitting saw also does a quick accurate job when you need it that good, but the bandsaw is the chopmaster, it is quite roomy though in the spatial department.
                      Michael W
                      #272774
                      not done it yet
                        @notdoneityet
                        Circlip may be right but it might help if the poster indicated how much needs to be cut off (or left on).
                        #272788
                          Hacksaw to length and slitting saw for the long cuts.
                          Alternative is to buy a Femi 780XL or 782XL bandsaw which will cut to length and the accesory table so you can use it as a vertical bandsaw to make the 200mm long cuts.
                          Edited By JasonB on 19/12/2016 16:21:15
                          #272878
                          mechman48
                            @mechman48
                            ​… Have one of ea. but my preference would be the angle grinder with 1mm cutting disc, plus many other uses as described.
                            ​George.
                            #272888
                            Bikepete
                              @bikepete
                              "angle grinder with 1mm cutting disc"
                              Handy indeed but throws nasty gritty sparks everywhere and is noisy. In a small workshop may be less practical. Also, angle grinders (especially with thin blades) are potentially 'scary' if you're not confident and firm of hand and arm. Any sort of saw is a lot quieter, cleaner and more controlled, if slower…
                              Edited By Bikepete on 19/12/2016 23:49:28
                              #272898
                              Matthew Reed
                                @matthewreed92137
                                Plus one for an angle grinder and the Aldi stand. The later is really neat, and ridiculously cheap, but could treated as a casting to make something very flash from. Then disks are also cheap enough at the moment.
                                Slightly alarmed at the thought of anyone using this inside their workshop. Sparks really fly, so it's strictly an outside job in my book.
                                #272900
                                Men Ifr
                                  @menifr84251
                                  Thanks for the replied. I made the long cut with the angle grinder and 1mm disk it took 5min and was not a nice job. I.e. can’t see the cutting line for the sparks flying in your facevetc. I did have the shield on and moved to catch as many sparks as possible but plenty still escape. Does the grinder stand stop sparks flying at you?
                                  #272902
                                  Carl Wilson 4
                                    @carlwilson4
                                    Grinder in a little workshop is a recipe for disaster. The sparks embed themselves in things really easily, like the bed of your lathe and the table of your mill. They are maybe ok in a rough as arseholes fabrication shop where that type of thing is of little consequence. Even then, maybe not. Definitely not for a precision tooling environment in my opinion.
                                    I used to have a 12" De Walt "abrasive chop saw"; basically a big grinder on a stand. It used to scare the living shit out of me. I used to use it while wondering what would happen if the disc burst. So I sold it to a guy at a local small fabrication firm and I put the money towards getting a Taiwan I think made horizontal bandsaw. It does a great job, it's quiet and no sparks!
                                    #272903
                                    Paul Lousick
                                      @paullousick59116
                                      An angle grinder stand only holds the grinder so it is square to the job. Sparks still fly. I use a couple of sheets of plywood to surround the area where I am grinding to restrict the area of flying particles. Still a messy process.
                                      A chop saw or small band saw (unless you can use it in vertical mode) will have problems making long cuts along the length of the angle.
                                      Making long straight cuts by hand takes a bit of skill keeping the grinder on line.  I have clamped a piece of flat bar to the plate being cut as a guide for the grinder wheel. (like you draw a straight line with a pencil and rule).  A light cut along the guide first (not all of the way thru) followed by deeper cuts.
                                      Paul.
                                      Edited By Paul Lousick on 20/12/2016 08:45:00
                                      #272952
                                        You should be able to see your line when grinding, start the cut on the end of the line nearest to you and work along the cut away from you, most sparks will go down through the work this way and behind the remaining line.
                                        Should be able to keep within a Sharpie line like that. Both these cuts were started from the edge and worked towards where they join. One hand holding grinder other to steady work.
                                        #273017
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi, wonderful thing is the 4 1/2" angle grinder and thin cutting discs. I cannot see what's scary about them, but I have used them for many years and have probably used well over a thousand or two thin discs. Couple of photos of some profiles that I cut at work today, using 75mm x 6mm flat steel bar.
                                          On the first photo the R/H cut along its length had to be plunge cut to start the cutting process, but the one on the left was started from the L/H edge and the short cut on the R/H side was cut from the R/H edge after I repositioned the G clamp. The cut in the second photo also had to be plunge cut to start with. All these cuts were done totally freehand and just following a scribed line. A quick tickle with a flap disc, soon dressed them up nicely.
                                          The important thing about using cutting discs, is to allow the disc to do the work. You will need a little pressure applied to the disc, but not so much to significantly slow the speed of the grinder down. Putting to much pressure on the disc causes it to wear away much faster and generate heat and the actual cutting process becomes slower. All the cutting on both of these pieces was done with just one disc with a still usable diameter left on the disc.
                                          Regards Nick.
                                          #273036
                                          Dave Halford
                                            @davehalford22513
                                            As to spark damage, never ever point the spray of sparks at any glass, they will melt in even if not still glowing.
                                            #273037
                                            Muzzer
                                              @muzzer
                                              Chopsaws and angle grinders make the most godawful noise and you get abrasive dust everywhere. And cheap and nasty examples make an even godawfuller noise. I bought a giant Xmas cracker quality chopsaw a few years back and got rid of it in a garage sale after only using it a couple of times and almost crapping myself.
                                              I have a 4×6 bandsaw myself and would recommend them. If you could get one new for under £200 or used for £100 or so, it's not a big investment.
                                              Like Brian_G, I've heard good things about the Evolution Rage thingies. They are only(?) £100 and seem to be pretty effective. I'd consider one of them if I didn't have a band saw, particularly if I also played with The Brown Stuff.
                                              Murray
                                              #273047
                                              Michael Briggs
                                                @michaelbriggs82422
                                                I have an Evolution Rage 4 cut off saw, I have used it to cut mild steel section for machine stands. Very noisy and hot metal chips everywhere but it did the job well enough. I tried it once with stainless steel, the blade lasted a few seconds. Regards, Michael.
                                                #273053
                                                Bazyle
                                                  @bazyle
                                                  By the way for those strangely doing this sort of thing inside you are allowed to build a car port structure (in UK) without planning permission up to garage size and can be out the back with no car access.
                                                  #273069
                                                  bricky
                                                    @bricky
                                                    I have used a jigsaw with a metal cutting blade for cutting 3mm plate lengthways,don't force the cut and patience is required .A word of warning about using angle grinders,not about safety but consequenses that have arisen from my use of the tool.I was asked by the client on site if I knew what was wrong with her window as it had become spotted and grainy.I didn't know.On another site I was cutting mesh close to the house and the sparks hit the window and the steel particles melted and stuck to the glass,which I had to replace at £400. Now I was aware of the dangers and what I had done to the first ladies window Which I peplaced for £80.Moving on to another extension I had to cut another lintel,the consevatory was 7mt long so I thought I would be safe,but The sparks had reached the far end helped by the wind and wrecked £650 worht of glass.Whilst cutting outside remember my experiences and make sur you have the sparks well away from any glass.
                                                    Frank
                                                    #273077
                                                    Roger Williams 2
                                                      @rogerwilliams2
                                                      Bricky, I did exactly the same to our patio window, I thought I was far enough away too !!.😥
