Bending copper pipe
Bending copper pipe
Home › Forums › General Questions › Bending copper pipe
  • #256999
    Mark Salzedo 1
      @marksalzedo1
      Hi,
      I have several lengths of used copper pipe (with nuts and cones on each end) which I need to use. What is the best way to make the pipe pliable, so that I can bend it to shape?
      Many thanks.
      #24746
      Mark Salzedo 1
        @marksalzedo1
        Bending copper pipe
        #257004
        Chris Gunn
          @chrisgunn36534
          Mark, just heat it up to red heat and let it cool naturally, do not hold it under the tap, then it will be soft. Be careful you do not crush it though. It will work harden if you keep working it, and you just reheat it and let it cool again and away you go.
          Chris Gunn
          #257005
          Mark Salzedo 1
            @marksalzedo1
            Much obliged Chris.
            Mark
            #257009
            martin perman 1
              @martinperman1
              I also find a nice long soak in the oven, when wife out for day, works well followed by slow cooling.
              Martin P
              #257030
              not done it yet
                @notdoneityet
                Apparently copper is one of those metals which remain soft after heating however it is cooled. Only work hardens. I have always cooled slowly, thinking it needed to be done that way, so as it works and it cools fairly quickly anyway, I have no burning desire to change. But nice to know it does not really matter.
                #257032
                Roderick Jenkins
                  @roderickjenkins93242
                  Yes, no need to cool copper slowly. I like to quench from hot into cold water because A) I'm impatient and B) it shocks some of the scale off and makes the pickle last longer.
                  However, Mark's original question says he has cones on the end of the pipe so if these are soft soldered and he wishes to keep them intact he is probably out of luck since the annealing temperature (about 400C minimum) needs to be well over the melting point of soft solder. Probably OK for silver soldered joints though it may be wise to put some flux on them before heating.
                  Rod
                  #257043
                  Hopper
                    @hopper
                    If you want to keep the soldered cones in place you will need a heat sink between the section being annealed and the soldered part. Dependiing on size etc, a pair of vice grips are often sufficient. For more heavy duty applications, a large potato forced over the tube will absorb an amazing amount of heat before it can get to the soldered section. (We used to use a sort of papier mache ball made from asbestos shreds and water but they won't let you do that any more) Trick is to heat the annealing section up quickly to dull red then plunge it in a bucket of water, thus minimizing the time available for heat to travel past the heat sink. If you know where your bends are going to be, you can anneal each of those specific areas one at a time to stop heat build up in the the pipe overall.
                    #257047
                    Mark Salzedo 1
                      @marksalzedo1
                      The cones are actually silver soldered in. Much obliged for all the helpful suggestions. Such a well of knowledge here.
                      Mark
                      #257061
                      Tim Stevens
                        @timstevens64731
                        If you have really tight curves to make, you will find it helpful to fill the pipe with something so that the bends do not collapse around the outside. Soft solder or lead can be used, and I have read that there is a plastic which works too. It has a low melting point and comes in pellet form but I cannot recall the name. Anyone?
                        And of course use a grooved former for the inside of the bend, too. This can be turned in hardwood to the size required, if you can find nothing off-the-shelf.
                        Cheers, Tim
                        #257065
                        Brian H
                          @brianh50089
                          I am fortunate in having a supply of Cerobend which is a strange alloy that melts in hot water, very useful for pipe bending but needs to be completly removed if silver soldering.
                          #257070
                          mechman48
                            @mechman48
                            It has been known to use sand packed into the tube, you can also get pipe bending springs of various diameters.
                            George.
                            #257132
                            Brian Wood
                              @brianwood45127
                              Whether or not Mark could get a spring into the pipe now that fittings are on each end depends on the internal diameters of the fittings and any hard solder residues.
                              ​The trick with pipe springs, as any plumber will tell you, is to over -bend as the first move, then ease the bend back to release the spring. The pipe tends to collapse onto the spring and there is no way the spring can be pulled out without damage to it if you don't ease the bend in this way
                              My early days of plumbing taught me that lesson, the expensive way. His other alternative is to use Cerrobend and melt it out with hot water afterwards. That resists flattening and creasing on the outer and inner sides of the bend, another hazard, especially creasing, that will trap a spring. Careful work with a sheet metal hammer around the sides of the bend is the only way of releasing one caught that way
                              ​Brian
                              #257154
                              john fletcher 1
                                @johnfletcher1
                                If you have over bent a piece of copper tube using a spring, useually if you wind up the spring in the correct direction the spring will come out, but it does take a lot of effort. In former times the heating and ventilation people who used 3 or maybe 5 inch steel heating pipe would fill the pipe with very dry sand with a cap either end and using Oxy/acetylene bottles to heat the pipe would make expansion loops on long runs. Now days they will have a hydraulic bender with a digital readout and key board. I think kiln dry sand as used by block pavers would be OK but make sure it is definitely dry. When I have used sand I always put it in the oven before use to drive out any moisture, ensuring I didn't generate steam and maybe blow the sealing caps off, ruining the job. Primitive but it works.John
                                #257355
                                david williams 14
                                  @davidwilliams14
                                  suprising how quickly some copper pipe work hardens. if you feel it go stiff, stop and reheat, really frustrating when a second bend breaks
                                  #257533
                                  Dave Halford
                                    @davehalford22513
                                    Posted by Brian Hutchings on 21/09/2016 10:11:21:
                                    A better use for that would be to cast some teaspoons out of it.
