Bearing removal, Chuck removal, motor cleaning (drill renovation central)
Home › Forums › General Questions › Bearing removal, Chuck removal, motor cleaning (drill renovation central)
Viewing 12 posts - 26 through 37 (of 37 total)
  • #240920
    duncan webster 1
      @duncanwebster1
      If you can't pull the bearing off then I'd cut through the outer race as Neil suggests then very carefully grind 2 flats on opposite sides of the inner race, As it gets near the shaft the very thin bit will start to blue from the heat, you then go even more carefully, eventually the inner race will come off. Two very small flats (and they will be small if you've been careful) will not matter. As someone above mentioned protect the rest of the shaft from grinding dust, I usually use duct tape wrapped on.
      #240969
      Rainbows
        @rainbows
        Well I'm skipping the front bearings cause I don't trust myself not to do more harm than good getting them out. They seem to be pretty well covered by gears and washers so unlike the other bearings they aren't scratchy.
        Re: Motor bearing
        Used bench grinder to cut flats into the bearing (as duncan mentioned). I felt it was a much better idea to do it this way instead of a thin dremel disk as I was going to, much less chance of nicking the commutator ring. First time I got a bit of a flat on the spindle, second time it went a lot better. Didn't cut all the way thorugh the bearing axially incase I hit the commutator but I gripped the weakend bearing loosely in the vice and twisted it out.
        Which leaves only one mechanical component to replace.
        Not immediately sure how to push this one out. Bearing is proper knackered so I can't screw it up any further though. I can sort of wiggle a screwdriver through the backhole so could use that to strike it out. Whether or not the inner would seperate from the outer is unknown.
        Bearing currently soaking in penetrative oil, if no one has a better idea I'm gonna gently heat the aluminium housing to expand it then try and punch the bearing out (only worry I have is shooting the inner race out and leaving the outer body stuck).
        #244139
        Rainbows
          @rainbows
          Project was shelved for a bit due to other more important work but got back to it this afternoon. FAG 608-2RS bearings fitted without issue.
          http://www.ebay.co.uk/itm/Carlube-Moly-Grease-Cartridge-Multi-Purpose-Lithium-Molybdenum-CV-Joints-400g-/371616918065
          Would that stuff be good for using on the gears? Molybdenum was suggested before but I don't know my grease grades too well so thought there would be no harm in checking.
          #244147
          Jeff Dayman
            @jeffdayman43397
            I'd try warming the alloy housing up to say 200 deg C with a heat gun, before pounding on anything. The bearing may drop out on its' own or may need a very light push after heating the alloy. The expansion of the alloy will be much greater than that of the steel bearing.
            As to grease, the new bearings will be pre-lubed and you do not need more grease than they come with. If you pack them full they will fail quickly. Ask your bearing supplier if you don't believe me. They will be able to recommend any grease you do need, based on bearing number. JD
            #244171
            Rainbows
              @rainbows
              Oh yeah bearing went great. Didn't have a heat gun so gently hit it with a propane blwotorch. Only needed a poke to make it come out. Putting the new one in went pretty easily too. Heated it again and used a plank to get it the last bit in. I meant about greasing the gears though, two spur gears in an aluminium housing (I can see how you could mix the messages, woops :P).
              As far as I can tell the best think for gears is oil but while the two shafts are now sealed the casing is just two casting held together by screws so I don't imagine thats a great seal.
              Also last thing, anyone recognise tihs white weirdness? Its kind off like a hard powder stuck to the casing. It was next to the switch. Hope the switch didn't blow up.
              #244186
              Martin Connelly
                @martinconnelly55370
                Looks like heat conducting paste that has dried out. Does the switch have any electronics in it?
                Martin
                #244215
                Rainbows
                  @rainbows
                  There was this grey card between the switch and outer casing, probably to stop the contacts touching the aluminium body. As far as I can tell the switch is all mechanical. Maybe its some sort of perished glue.
                  #244231
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi Rainbows, your white weirdness is most likely caused by moisture trapped between the card and the casting, it's not unusual on die cast.
                    Regards Nick.
                    #244292
                    StephenS
                      @stephens
                      Hi Rainbows,
                      That grease would do although it is NLGI 2 which is the average grease for car greasing, wheel bearings, etc. It is a thicker grease than I would want to use in CV joints even though the ad for it mentions CV joints.
                      I would prefer a slightly thinner grease and the one I would look for is the CV joint grease that comes in little foil packets. It is a thinner grease than the one you mentioned, and will cost a bit more, but it is also a higher moly content I have been told.
                      There will be others on here who know far more than I do about grease ratings so maybe they will be able to shed more light on this.
                      Cheers, StephenS.
                      #244294
                      StephenS
                        @stephens
                        I have talked about CV joints above, but I do realise that you want this grease for your drill gearbox.
                        The thinner grease with more moly in it should not dry out as quickly, and the moly should lubricate the gears themselves really well, and it should not leak as long as the gearbox housing joints fit reasonably well.
                        Cheers, StephenS.
                        #244302
                          Assuming the casing is a tin/zinc alloy pressure casting not aluminium (which is likely) en.wikipedia.org/wiki/Wet_storage_stain
                          Rainbows
                            @rainbows
                            White rust sounds right. I got a Moore & Wright bearing scraper at a carboot yesterday which was pretty useful for picking out the white stuff. There isn't any sort of pitting underneath so its all good.
                            I will see if I can find any moly grease with NLGI 1 on the packaging for the gears.
                            Only other thing I'm waiting on is for some cap head screws to replace the slotted ones used on the case. One of them had the head tear off and another was on the verge of stripping, high tensile bolts are so much nicer to work with.
                            The other plan to spray paint everything to original colour is abandoned. I'm not sure how it was painted originally and I'm not sure of the colour and the brass name plate is rivetted on so I jsut went hell to it.
