Posted by Mike London on 12/04/2020 11:53:28:
The drills haven’t been used for awhile and a couple of days ago I had a job on, got the drills out. The batteries were dead. No problem, put them on the chargers and start work. Except none of the batteries will charge!
Four batteries dying at the same time? Bit unusual!
Two chargers dying at the same time? Bit unusual!
What happens if I put the car battery charger on it?… It shows 19.5 volts, not bad for a 13 volt charger output!
Maybe I have invented perpetual motion?…
Without knowing exactly what the batteries are it's difficult to comment beyond noting that rechargeable batteries tend to go flat if left alone and self-discharge is thoroughly bad for them. They perform best and last longer when they are used and fully recharged regularly and often.
In the good old days secondary batteries and rechargers were both basic; a pair of right thickos, fairly easy to understand.
Unfortunately a simple battery/recharger combination doesn't get the best life or performance. Big Lead Acid batteries were originally managed by a man who carefully adjusted the charger and acid density manually. Later chargers cut the man out by making the charger sensitive to the state of the battery (an imperfect arrangement, but cheaper than paying men.) Improvements in Lead Acid technology optimised motor car batteries for simple recharging and low maintenance – we don't even have to top them up any more.
Over the years chargers got ever more complicated. Quite a few recent battery technologies are intelligent, including built-in electronics monitoring the state of the battery to improve discharge, and cooperating with the recharger to extend battery life. Some contain buck converters that alter and regulate the output voltage and current.
Hard to know if the batteries in Mike's drill are smart or stupid, and if smart, what on earth they're thinking.
I suggest the batteries flattened to the point were the internal intelligence and/or the charger lost the plot, failed to recognise they were batteries, or simply decided they were dead and gone. Putting the batteries on a deeply stupid car charger may have put enough energy in to wake them up again. But I doubt they are in 'as new' condition.
The 19V / 13V thing is easily explained. A car battery charges at about 13.8V, so the charger's mains transformer is wound to output 13.8V on average, which is 19.5V peak on an AC or half wave rectified DC. When the charger is connected to a capacitor or battery, the DC voltage floats up to peak, which is read by the meter. It's not perpetual motion.
Lots of battery 'fixes' out there. Fair enough when used as a way of squeezing more life out of a deceased battery, but the battery isn't restored to full capacity and won't be up to specification reliable. I've rejuvenated car batteries for personal use with great success – getting another 6 to 9 months out of them. Passing them off as part of a second-hand car deal is dishonest.
