Air/Gas compression in a Steam Engine.
Home › Forums › Beginners questions › Air/Gas compression in a Steam Engine.
  • #245430
    Ed Duffner
      @edduffner79357
      Hello guys,
      I have been toying with a basic steam cylinder and piston design in Fusion 360 and thinking about how and when steam would enter and exit with a slide valve.
      So, after the steam has done it's job pushing the piston to the extent of its travel BDC? and the piston starts to move back, is there some compression of air/gases in the cylinder which can have a dampening effect i.e. slowing the motion down? or does the exhaust port stay open until the piston has reached it's TDC? position again?
      Ed.
      #8201
      Ed Duffner
        @edduffner79357
        #245462
        John Olsen
          @johnolsen79199
          Hi Ed,
          It depends a bit on the particular design, but it is usual to start admitting steam just before top dead centre. This can help reduce the load on the bearings as the piston reverses direction, and also means that the valve is more fully open when the steam is really needed, eg as the piston starts to go down the bore.
          On the cutoff side, most valve gears are designed to cut the admisssion of steam off part way down the stroke. This allows the steam to expand for the remainder of the stroke. With a simple valve gear the cutoff will be fixed, but the more sophisticated gears allow varying the cutoff. So for instance on a locomotive, for starting the cutoff will be late in the stroke, allowing full boiler pressure on the piston for almost the full stroke. This gives the maximum torque, at the expense of using a lot of steam. When the exhaust opens a cylinder full of steam at full boiler pressure will go to waste. Once the train is rolling the steam will be cutoff much earlier in the stroke, This reduces the torque a bit, but gives much more economical use of steam.
          On the exhaust side the valve is usually open for most of the stroke, but in some cases the gear is designed to close the valve as little before top dead centre, with the idea that the compression will help cushion the piston as it reaches the top.
          There are some special cases, for instance winch engines and steering engines for ships were usually designed to admit steam for the whole stroke and similarly to exhaust for the whole stroke. This is partly in aid of giving good starting in any position, and partly because such engines never run very fast or for very long, so the extra economy of a short cutoff is not needed.
          Another different arrangement is the uniflow engine. These have a valve for admission and a set of ports like a two stroke engine for exhaust. Steam is only admitted for a very short period, maybe 10% of the stroke. The exhaust is only open when the port is uncovered so for most of the return stroke the steam in the cylinder is being compressed. This gives very good economy but such an engine will not self start well unless it is in the right place. They were popular for stationary engines driving mills and factories.
          Ed Duffner
            @edduffner79357
            Thank you john, very clear and understandable information!
            Best Regards,
            Ed
