Hi guys
Chart showing 15.8 another saying 15.5 😀
so i am going to be assuming that its is 15.5mm for the hole and thread it with the m18 2,5 and go with that with 18mm bar & thread also with same m18 2,5 not received the bar yet so cant try until i get it . I am trying to fix something that i received from USA for wood working ,self centering vise for dowels which is very poorly made and all joins are very loose and inaccurate so i was thinking its time to learn something new to help me fix other things.And try to make this work as intended with a much more accurate fitting sliding joins here is an image
of the thing not my one but one from the internet ,Because my one is in bits lool .
All so the center bar is threaded with two threads in reverse so that it can open close each side at the same time to make a self centering vise but in this case is not doing a great job so my mission is to fix that 😀
By using stainless still bars 10mm for each sliding bar and 18mm for center with 15mm Aluminium flat bar ,Width 80mm x 155mm x 2500mm cut in two parts ,to match the vise setup .only one thing i am going to keep out of the one from US is the middle part .If i had more skill and new much more which i dont and is very little at this time i would make it all ,
Thanks guys
if you would like to see it in bit i can post np
Edited By Karl Fuller on 06/11/2017 20:11:50
Edited By Karl Fuller on 06/11/2017 20:12:22
