Amazing how a discription can be mis read, in this case on my part?
The way I saw it was a 5mm radius is 10mm diameter, with a 7.5 mm slot running into it over 20mm
So, set up in the mill and find centres, fit 10mm end mill, move to desired position and plunge in for the thickness required, then, run back out keeping centres aligned, change cutter for 7.5mm (probably accurate enough in this instance) and then run back in to the 10mm dia hole
Simples
However, as some have said, a picture would have helped greatly.
Edited By *.* on 11/02/2018 13:10:23
