Home › Forums › Beginners questions › what width bed is an ml10 please
can someone tell me the answer to this please the widle of a ML10 bed
Cheers
martin
Mine's 3 inches
Mine's 3 inches
That's bigger than John's ![]()
Edited By Michael Gilligan on 04/09/2016 13:33:40
Thanks a bit late am working on a new project to convert ML10 tail stock to Drummond 3.5" bed. This is the first idea i come up with to cut down the ML10 saddle to bolt onto the Dummond Saddle kike the old one did making a mating surface for the new MT2 tailstock.
Here i s what i started with
Here is the bottom part
Here is it cut down on image software
Cheers
MN
Edited By Martin Newbold on 08/10/2016 18:48:36
Edited By Martin Newbold on 08/10/2016 19:07:51
I am hoping at least one of the screw holes will line up.
Still working on it
Edited By Martin Newbold on 08/10/2016 19:08:42
A bit late to the party but…
It might be worth using a center in the spindle nose rather than a chuck? Might be that bit more accurate?
Here is the reverse showing the ML10 interface with the old Drummond saddle which was under existing tail piece.Provision has been made to retrofit the MT1 tail piece should it ever need to be. Stil have approx 2mm to remove from top was able to remove approx 3mm from bottom. Am going to take it slow here so i can get it as tight as possible 1mm at a time.
MN
Yep Steven , thanks for the tip . I am still considering how to get it dead accurate . I need a 5/8 16 MT2 for my chuck to get the big chuck on it to hold something other than what I have . I have about 2 mm to remove approx so am going to take another 1 mm before I get into working out how to get it exact any ideas would be really helpful. Wont do this until next week.
MN
All very interesting, but are we not missing the obvious here. The centre height of an ML10 is a known dimension. So why are you messing about trying to match a centre to the centre of a set of chuck jaws, or to another centre mounted in the headstock or a chuck?
Why do you not simply assemble your tailstock, then measure the position of the centre and simply machine the base, however constructed to match the known ML10 centre height? It seems so straightforward to me, or am I missing something here? It almost feels like you are all trying to re-invent the wheel to me.
I have just looked at the photos again. Is it me? You don't even have a complete centre in the tailstock, so how do you hope to match up the tips of the 2 centres when of them is not actually available to line up?
If you turn a taper onto a piece of bar stock – or better still, take a skim cut on a dead (ie soft) centre – you will end up with a dead accurate indication of the true centre. Doesn't matter what the spec sheet says or even what you measured – the point you cut will be at the actual centre height. If you remove the bar or centre, you should probably re-skim it each time.
Hi Mike,
It’s going to need the surface milled off to line them up. I have not an MT2 dead centre at present as one is on order but has not arrived.
I might be able to borrow one before i start taking more material away on Monday. The ML10 may be a known dimensions but the Drummond is not known by me. In addition this is made from a construction of the ML10 tail piece to mate onto the existing Drummond 3.5" wide bed slide. Thanks for the criticism I think
