4″ independent lathe chuck recommendations and holding capacity
Home › Forums › Beginners questions › 4″ independent lathe chuck recommendations and holding capacity
  • #245629
    carl too too
      @carltootoo67401
      Hi all first of all nice to meet every one I'm new here..
      I have a small myford M type lathe 1950's 1 x 12 tpi whitworth thread,At the moment i have a 4 1/2" 4 jaw chuck but the chuck is showing some serious problems with regards the where the jaws ride along the chuck and screws.They are bell mouth the jaws as the screws tighten the jaws seem to be pushing up and out..So i need too purchase a new chuck..
      I'm mainly working with 2" round stock at the moment and wondering if a 4" chuck will still be able to Cary out this task without switching the jaws around..I would like to have the full use of the jaws in there normal position..
      This leaves me with one or two things either look for a 6" chuck which,From what i have been told is a little big for my lathe..Or the 5" chuck..Or if a 4" is capable of holding 2" stock in their normal jaw position a 4" chuck.
      If i can still use a 4" chuck to get hold of the 2" stock with the jaws in there normal configuration, i will be able to use the same back plate i have for the 4 1/2" I'm using at the moment as its brand new and i have not long turned the back plate for that specific chuck and i can turn it down to the recess for the 4 1/2" chuck as its at 4.100" so just have to take it down to 4" then do the new recess for the new chuck…
      Sorry if this doesn't make seance I'm looking for some recommendation on a new chuck.From what i have read people are saying the vertex chuck is good value for money,So that was my first choice..I noticed there is a sharp chuck out now not sure of the quality of that chuck though..
      I don't want to spend over £100 on a chuck for my lathe has any one any experience with HBM chucks i have heard good things about those as well..
      It would have to be front mounting as i don't have transfer screws or a milling machine..
      Any recommendations would be very much appreciated
      Thank you all have a nice week
      Carl
      #8204
      carl too too
        @carltootoo67401
        Any help would be great thanks
        #245638
          Carl,
          One of the M-type owners will advise, I'm sure, but I think a 6" 4-jaw should fit, physically.
          If you are willing to modify one, by making an insert; the lightweight version from Burnerd would probably be ideal. [These have a screwed body, to fit the ML7 nose.]
          MichaelG
          #245639
            A 4" 4-jaw will hold 2" stock easily, it leaves 1" of jaw engagement which is plenty at that size.
            If you want to spend ~£100 try looking at HBM, Zither and Vertex.
              For info: The second photo on this ebay listing shows the four big cavities that lighten the 6" Burnerd.
              Roy James 2
                @royjames2
                Carl.
                I have a small Myford M type Lathe with the small 7/8" 9 or 12 TPI thread,( not sure which ) I'm going through the same process as you, requiring a larger chuck, I would think twice if I were you about the 6" chuck, mainly because of the weight you would impose on the smaller mandrel.
                A 4" lightweight one will be my choice
                Michael G.
                What sort of insert are you thinking of,a reducer from a myford thread to the 1" thread on Carl's lathe ?
                James
                #245664
                  Posted by Roy James 2 on 06/07/2016 23:23:24:
                  Michael G.
                  James
                  James,
                  Always assuming that the 6" diameter is realistic for the lathe [which, surprisingly, no-one has yet confirmed or denied] … What I would do is, bore out the ML7 thread to its register size, then fit a plug [good ol' Loctite 638] and bore & thread that to fit the 1" nose.
                  N.B. … I have a couple of the Myford-Burnerd screwed body 4-jaws and they are much lighter than a standard chuck.
                  P.S. … This thread, from 2015, may be of interest.
                  Edited By Michael Gilligan on 06/07/2016 23:47:43
                  #245665
                  carl too too
                    @carltootoo67401
                    Hi all thank you for the input,The 4 1/2" lathe chuck i have on at the mount is an old cast iron chuck and has allot of weight to it,I have a 1" x 12 TPI spindle should be fine for a 4" to 5" chuck,I know people who have big 6" full bodied lathe chucks on there lathe with no issues,
                    This 4 1/2" cast iron one weighs allot and there has been no issues,Also i use good lubricant and have bronze bearings i know its not the best but better than Babbitt bears..
                    I know if i go with a cheap in port they are chunky and heavy..So i might go for a slimline one yet,would a reducer not just make the spindle further away from the chuck,which would be worse if I'm thinking right
                    Its going to be a difficult decision i think the first thing i will do is weigh this chuck i have on at the moment as i know its perfectly fine..Looking at the specs of these chucks the vertex 4" supposed to weight the same as the 5" but that doesn't sound correct..
                    Thank you all for your help its Very much appreciated,On the drummond forum i have seen some big chucks mounted to some small lathes lol..But these myford M types are much stronger than the drummond spindle as lathes website mentions the reason for upgrading the spindle threads from 3/4" to 1" was to stiffen the lathe up and and rigidity.
                    Its the big chunky inport ones that worry me i've had one before and resold it was a heavy bugger..
                    Thank you
                    Carl
                    Guys they do a light weight 6" with a normal recess just like the ml7 ones without the thread..
                    Edited By carl too too on 06/07/2016 23:51:54
                    #245666
                      Posted by carl too too on 06/07/2016 23:50:24:
                      … So i might go for a slimline one yet,would a reducer not just make the spindle further away from the chuck,which would be worse if I'm thinking right
                      Not if you do it the way I described
                        The lighweight ones are also available for backplate mounting which may be easier than trying to convert a threaded one. I have a Bison one on my lathe.
                        #245687
                          Posted by Michael Gilligan on 06/07/2016 19:45:15:
                          That does look a good deal, assuming there's enough room in the gap to make use of the full jaw travel.
                          carl too too
                            @carltootoo67401
                            Hi guys trying to thread an internal bore on a 6" chuck just is not going to work..Just like making an adaptor unfortunately the chuck I'm using has to much play to do this and would only pass on my issue to the new chuck preferably would like to have the front mounting screws..
                            Although I'm not a big fan of RDG for my own reason they do a 100mm slimline 4 jaw for £75 not sure what the quality will be like but they look to have sold over 126 if not more with no complaints about them..I know it would be nice to have a Bernard or bison or similar chuck,But i just don't have the faith in finding a decent 6" 4 jaw on eBay without taking a big risk..
                            I have been in touch with 2 sellers about the chucks they have and one seller said buy a new one,I asked him if the chuck was in good condition and the rails where ok and screws and asked for some closer photos of the jaws and screws and rails.
                            And also asked if the jaws where binding in any places..Not good to turn around and say buy a new one :D..
                            So either going to wait a few weeks see if any thing decent comes up on eBay and take the risk or go with the RD slimline 100mm one belongs i can get the 2" stock in there ill be happy..
                            Carl
                            #245756
                            bodge
                              @bodge
                              Hi Carl,
                              If you have a look at Arc euro`s site on the chucks page, they give the spec`s for their chucks, weights and dimensions . Have also been thinking about getting another 4 jaw indt , my first choice would have been TOS but they have got a bit pricey of late, so second choice will be Zither from Arc Euro,
                              Welcome to the forum , also have a Drummond 1903 model . ……….bodge
                              #245777
                              carl too too
                                @carltootoo67401
                                Hi bodge
                                Yeah was looking at there chucks mate the 5" weighs 3.5kg and the 6" weighs 4.5kg so would probably go with the 5" they look like ok chucks made in India i believe.. £120+ but i think,cast iron from 5" to 6" and the 4" is steel and only weighs 2kg sounds good..
                                Carl
                                #245780
                                bodge
                                  @bodge
                                  Posted by Micheal Gilligan 06/07/2016 20;37;05
                                  Yes Micheal , i do remember the thread and also posted on said thread and did think at the time it was a bit over chucked and said as much to that effect, I thought he might have got away with it as i have seen Ml7s fitted with 5 inch 3 jaw chucks both in the flesh and in magazine articles over the years and as id not heard or read any thing about being detrimental to the life of the bearings, but that proved not to be so and if i remember correctly Myford sent an E mail stating they advise against fitting said chuck, if i remember right the chuck was branded HBM or HMB
                                  As it happens i have HBM or HMB 5 inch chuck (it came with a lathe i bought for repair/ spares, not sure which as yet ) it makes a good door stop !
                                  I read a post on here recently that TOS were making chucks for Pratt-Burnard but not the griptru ( think it was a John Stevenson post ) as for Zither so far all i have read about them has been good and Ketan from Arc Euro has posted on here more details of manufacture and standards they conform to and stands by them as being good chucks
                                  I know Carl says he would have liked to stay below 100 quid mark (as im sure we all would) but you get what you pay for, its been said on here before buy cheap buy twice ! If you think about it there`s two points of contact on the work piece , the chuck and the tool so make the chuck a good `un hopefully you will be using it for many years to come so its worth going a bit over budget
                                  On a final note i do think the 6 inch chuck is going to be a bit heavy for the spindle on your lathe ,………b
                                  PS third choice would have been Vertex
                                  Edited By bodge on 08/07/2016 03:47:08
                                  Edited By bodge on 08/07/2016 04:04:36
                                  #245782
                                    Posted by bodge on 08/07/2016 03:43:54:
                                    Admittedly it's on an ML7 page, but I think this [from lathes.co.uk] is a fair summary:
                                    [quote]
                                    … The "threaded body" chucks were always the preferred choice, being designed to allow as close a fitting to the spindle bearing as possible, so reducing overhang and improving rigidity. Internally-threaded, and of a half-depth body design for lightness, the 6-inch diameter 4-jaw Burnerd chuck was designed to reduce the load on the front spindle bearing and had its mounting thread well recessed into the body. … … The 6-inch diameter Burnerd 4-jaw chuck is the perfect solution for those large and awkward jobs that would otherwise take too long to set up on a faceplate – and a good used one is well worth seeking out.
                                    [/quote]
                                    Now the 'M' lathe has a 1" thread and [correct me if I'm wrong] an MT1 taper; whilst the 'ML7' has a 1.125" thread [1.25" register] and an MT2 taper. … I have not done any math on this, but gut-feeling is that there is very little chance of the 'M' spindle failing under the weight of this chuck.
                                    … Compare the rather magnificent faceplate with which it was supplied !!
                                    Edited By Michael Gilligan on 08/07/2016 06:58:40
                                    Edited By Michael Gilligan on 08/07/2016 07:00:25
                                    #245795
                                    Ian S C
                                      @iansc
                                      I think the more important thing to think of is over loading the chuck, rather than the chuck its self, although for this lathe a light weight chuck is the ideal to look to.
                                      Ian S C
                                      #245796
                                      Ajohnw
                                        @ajohnw51620
                                        Other than Myford I don't think I have ever seen any direct screw fit chucks for other lathes. All use back plates. Other types of fitting too.
                                        Chuck size is an odd area. Manufacturers do have a tendency to fit the smallest 3 jaw they can get away with and even offer a larger one as an alternative at times. The traditional 4 jaw for a particular lathe will generally be larger than the 3 jaw and slimmer too. I suspect that Myford chuck weight came more to the fore when the big bore arrived. I can't recollect any mention of it before that and my Myford came with the larger 3 jaw and I can't recollect ever seeing one with the smaller chuck.
                                        As this is a smaller lathe I suspect a 5" 4 jaw would be the best answer but if the op can't turn up a back plate he's likely to have problems. He could probably just about get away with holding a back plate casting in his current 4 jaw with the jaws reversed. College Engineering offer a 5 3/8 dia one which is probably too big but the spigot could be held first to turn down the OD a bit. They also do a 4 1/2" back plate.
                                        The other point is that 4 jaws usually last well as they aren't used that often. I can't help wondering if bell mouthed jaws are really loose headstock bearings but people have been know to machine jaws and if the lathe isn't perfect the result will be bell mouthed jaws.
                                        If the OP chooses to buy a used chuck it's worth remembering that there are several old makers that produced chucks that are just as good as Bernard. There is a small Crown on ebay at the moment for instance. There are others that crop up now and again.
                                        Just add that if anyone does make a back plate it really is a good idea to make a dummy spindle nose first. It can be checked for fit into one of the other chucks that are known to fit well or measured VERY carefully as it's made. The main aspect to get exactly correct is the register diameter but ideally the thread needs to be very close too.
                                        Edited By Ajohnw on 08/07/2016 10:08:04
                                        #245797
                                          Just for the record …
                                          According to my [uncalibrated] Bathroom Scales; the Pratt-Burnerd 'Light Duty' Myford fitting 150mm/6" 4-jaw chuck [Catalogue No. 1548-16130] weighs approximately 3.5kg.
                                            Posted by carl too too on 07/07/2016 19:18:14:
                                            Hi guys trying to thread an internal bore on a 6" chuck just is not going to work..Just like making an adaptor unfortunately the chuck I'm using has to much play to do this and would only pass on my issue to the new chuck …
                                            Carl,
                                            I did not suggest threading an internal bore on a 6" chuck … I suggested making a suitably threaded insert, to fit a plain bore. … By doing things in the right order, and setting-up carefully as you proceed, it should be simple enough.
                                              Re: Part Numbers for the 'threaded body' chuck
                                              see Adam's closing note: **LINK**
                                              #245865
                                              Nicholas Farr
                                                @nicholasfarr14254
                                                Hi I have a 6" Bernerd light weight four jaw chuck that looks the same as the Pratt and Bernerd ones that have been linked to.
                                                This one as Jason has said, is made for fitting a backplate. The backplate that is fitted to it is for a Myford ML7, code number on it is SK8052. The chuck is 1 5/8" thick and has a bore of 1 5/8" and weighs 4.1 Kg on it's own and 4.66 Kg with the backplate fitted. One thing about the backplate is that most of the threaded portion protrudes into the bore of the chuck, thus keeping the overhang to a minimum.
                                                I don't have a lathe that this fits onto, although I do have a Myford M type with a 1" x 12 thread ( which incidentally I believe is UNF and not Whitworth) but I don't have a backplate to fit it, but the three jaw chuck that is on the M type is about the same weight, although I have never used it as it's just one lathe that I have waiting for an overhaul. Another old un-badged lathe that I have has a four jaw that is threaded into the body, but I don't think it is a Myford, I think it looks more like a RandA design, although it has a spindle nose the same size as the Drummond round bed lathe.
                                                Regards Nick.
                                                #245871
                                                  Very interesting, thanks Nick.
                                                  Perhaps I should re-weigh mine on some better scales.
                                                  bodge
                                                    @bodge
                                                    Hi Carl & Micheal G
                                                    Micheal i fully agree with what you are saying, and would have gone down the route you suggested, ie turn the thread out of P-B chuck and bushed it to suit the spindle to get the best of both worlds , largest capacity and minimal over hang i dont have a problem with that . Though one may need another lathe with the capacity to do so, though i suppose one could leave the old back plate on the spindle and then use the chuck jaws to hold the chuck to the back plate which would let one get the tool in place to turn the thread out.
                                                    Trouble is one then needs to screw cut the internal thread in the bush, as you said careful planning the operations and also the ability to work to a high degree of accuracy will be needed, this maybe a bit daunting and will depend on ones level of ability, which is an unknown factor ! The inverted back plate as shown in Nick`s photos looks to be a good idea. I would rather not get into another debate like the ML 7 post as it didnt go well at the end of the day ! so hopefully someone with a 1 inch spindled Drummond M type will advise on chuck size. so to answer the question as asked in the first post which make of chuck would one buy, for myself i would go for TOS, Zither or Vertex or a good condition S/h P/B ………….b
                                                    #245911
                                                      bodge,
                                                      Nick's version of the lightweight 6" would probably make Carl's job easier ['though it's the only example I have ever seen] … But here's what I had in mind for the screwed-body version:
                                                      • Using Carl's existing chuck; on a short length of [say] 1.5" diameter bar, make a nicely fitting 'female' to fit the spindle nose. … See Ajohnw's comments above.
                                                      • Screw this onto the nose, and skim the outer diameter 'parallel & true' [any size over 1.25" dia.]
                                                      • Clamp the new 6" [reversed] onto this 'mandrel', adjusting until its register diameter runs true.
                                                      • Bore out the ML7 screw thread, to leave a plain bore through the chuck.
                                                      • Remove the chuck from the 'mandrel'
                                                      • Skim the 'mandrel' to a close sliding fit in the chuck bore, and trim to length.
                                                      • Assemble with Loctite 638 Retainer
                                                      • … Enjoy …
                                                      What do you think ?
                                                      P.S. … I have the 100mm/4" Pratt-Burnerd 'front fixing' 4-jaw, but this is mainly used on the Rotary Table. Personally, I would not consider it suitable for 'heavy' operations on 2" dia stock in the lathe.
                                                      Edited By Michael Gilligan on 09/07/2016 08:21:11
