I’m pretty sure I screwcut the last edit backplate I did, before finishing it with the tap. The difficulty I had with that, as that it was strapped to the faceplate, which has quite a small centre hole, so I was constantly worried about crashing the screw cutter. So I did what I could and finished it off with the tap. In practice it is accurate enough for a 3 jaw.
Somewhere I still have the cutter I ground for making that screw. Tbh the problem might be that there could be a small amount of wear on the lathe lead screw, which could result in a slightly less than perfect thread. But I guess that’s where the tap comes in.
This backplate is much smaller and the blank can probably be held in my existing 3 jaw, which makes the whole thing much easier to do on the lathe. I remember fixing the last one to the faceplate was tricky.
The problem is the 3 locating holes. I’m pretty sure that last time, I simply used the chuck as a template, centre punched them and drilled them on the pillar drill one by one. To do them on the CNC could actually be tricky. It looks like their centres is 1 inch from the centre of the central mounting hole… and it looks like they are 120 degrees apart. But that may not be exactly the case! Using the chuck as a template seems like a good idea.
