drain cocks
drain cocks
Home › Forums › Beginners questions › drain cocks
  • #234220
    John gallo
      @johngallo38006
      Hi, I am installing drain cocks on my Stuart Beam engine. I would like them to be sitting vertical, but they tighten down at an odd angle.
      Is it possible to back them off to the vertical position and use high temperature thread sealant to lock them in place and make a steam tight seal?
      I am very new to model making and have no experience with this sort of thing. Please feel free to voice any other fixes you think may work. Thanks, John.
      #8098
      John gallo
        @johngallo38006
        #234221
        Ian Parkin
          @ianparkin39383
          Stuarts used to do alloy washers in a variety of thicknesses to get your fittings to the correct attitude
          #234222
          roy entwistle
            @royentwistle24699
            you can get both aluminium and copper shim washers for such a situation
            #234227
            stan pearson 1
              @stanpearson1
              Hi John
              If you go to [email protected] you will see them under washers 20 in a packet 5 of 5 different thicknesses , no connection with the company.
              Stan
              #234228
              Nick_G
                @nick_g
                I have put 'Boss white' onto the threads. Screwed in as far as it will go then backed off to the desired position.
                After a couple of days this will have cured and the drain cock is secure but able to be cracked off and undone if required.
                Nick
                #234229
                duncan webster 1
                  @duncanwebster1
                  loctite hydraulic sealant works a treat
