Slot drills, two for one.
Home Forums The Tea Room Slot drills, two for one.
  • #423606
    Vic
      @vic
      I ordered a long series slot drill from the auction site. Two standard ones turned up today … I won’t give them bad feedback because I suppose two short ones equals one long one! laugh Still need a long series one though.
      #35579
      Vic
        @vic
        #423609
        Kiwi Bloke
          @kiwibloke62605
          Perhaps the same helpful folk would send you two 3mm dia end mills if you ordered one of 6mm dia.
          #423615
          Vic
            @vic
            Funnily enough it was a 6mm I ordered. They will get used and at only a couple of quid it’s not an upset. I’ve found a UK supplier doing them for about £9 so I’ll add that to my next order for inserts.
            #423625
              Here’s hoping they are not 1/4” instead of the metric! 19mm/3/4” may not be too bad for most things, but 16mm/5/8” can definitely mean a nuisance difference.
              #423653
              peak4
                @peak4
                Whilst I was still at work, one of our planners ordered me enough cable for a 130m cable run of 16 core co-ax; Stores sent me a 100m drum plus a separate 30m coil. Ho Hum.
                Bill
