Cutting Carbon Fibre
Home › Forums › General Questions › Cutting Carbon Fibre
  • #592645
    Paul L
      @paull58212
      A friend of mine is a Band Leader and has snapped his conductor's baton. He has asked if i can repair it as it was a gift from his good Lady.
      As you can see in the photo the break is not clean. my idea is to cut it clean and insert a metal rod (its hollow) and bond it back together.
      Does anyone have any experience or suggestions as to how to get a clean cut through Carbon Fibre?
      Thanks in advance
      #28650
      Paul L
        @paull58212
        #592646
        Paul L
          @paull58212
          #592647
          Clive Hartland
            @clivehartland94829
            I would suggest to grind it flat, use an aluminium tube inset and araldite it in place.
            #592651
            Paul L
              @paull58212
              Thank you Clive, i hadn't considered grinding it.
              #592652
              David-Clark 1
                @david-clark1
                Horrible stuff to machine. Splinters and burrs are common. I would probably araldite a piece of metal in each end, Then face back to clean up while in a collet. Face right up to the collet face. Then drill and tap both parts and glue some threaded rod to pull it all together.
                Maybe glue a polished brass band over the join to hide it?
                #592654
                  I agree with Clive … but might use more carbon fibre tube to keep the weight down
                  …. would also note that you would be wise to check how far the cracks extend.
                  From what I can see of the photo, the baton is more likely to be a ‘pultrusion’ than a ‘filament wound’ tube.
                  John Haine
                    @johnhaine32865
                    I hold the tube in a collet in the lathe and use a pointed tool at low speed to nick through far enough to get a clean break. Square off with fine abrasive paper. Araldite + ali tube or rod to reinforce will be fine. Need the metal to be a nice fit in the CF tube. My 7kg clock bob has been hanging off an 8mm aluminium slug araldited into 10mm OD 8mm IS CF tube for over 3 years with no sign of coming adrift.  Gluing in a slug also holds any longitudinal cracks together.
                    Edited By John Haine on 03/04/2022 09:41:02
                    #592663
                    Ady1
                      @ady1
                      Would heat work to seal the ends and then rub them flat? you would need a metal insert in the hole
                      My jobs with fishing rod and umbrella carbon fibre have always been a bit of a nightmare
                      Edited By Ady1 on 03/04/2022 10:02:40
                      #592665
                      Clive Brown 1
                        @clivebrown1
                        How much strength is required? I think that any type of internally reinforced butt joint will be quite weak as the fibres are discontinuous and will not carry bending stresses. An angled splice joint might be better but difficult to make unobtrusively.
                        #592666
                          Diamond coated disc in a Dremel works well
                          #592668
                          Paul L
                            @paull58212
                            Thanks for the suggestions.
                            The baton is tapered and is 3.8mm at the break point. Normally the only stress it encounters is being wafted through thin air!
                            I'm going to try the Dremel idea of Jason's, then ally welding rod and araldite.
                            I may post the result later if its not too shameful.
                            #592669
                            Ady1
                              @ady1
                              Check out a couple of fishing rod repair sites?
                              "fixing a carbon fibre rod tip" could yield decent returns
                              #592670
                                Never tried to repair Carbon Fibre so I'm short of ideas. I think it's too difficult. Carbon fibre rod is made of extremely thin carbon fibres embedded in a brittle resin matrix. Rod is very strong along the fibres, much less sideways. This picture is of the suspension of my experimental clock pendulum, where I removed a section of matrix so the pendulum only swung on the flexible fibres, independent of the resin. The example is 0.8mm diameter, but the construction is the same in bigger diameters.
                                Appearance depends on the matrix, which should be easy enough to recreate. Unfortunately, the strength of the rod depends on the fibres, which can't be reconnected. The best I can think of is like Clive's answer, except I'd use a steel rod rather than Aluminium tube. (Carbon fibre is stronger than steel!)
                                I found cutting thin rod no problem with a wire-cutter or rolling a sharp Box Knife over it, but it gets harder to do it neatly as the rod diameter increases. Radio Control types recommend rolling the rod on a wet cloth with a razor blade. The problem is the brittle matrix tends to crack and chip, causing nearby fibres to stick out in an untidy fuzz. A Dremel cutting disc might do a better job: I've not tried it!
                                My feeling is the item can be made to look good again, but the repair won't be strong enough to allow the baton to be waved about.
                                How about the dead Hamster fix? When the child's favourite pet dies, take the corpse to a pet shop secretly and replace it with a near match. If all else fails, tell the friend to substitute a new one without telling his wife!
                                Journeyman
                                  @journeyman
                                  Many older batons, especially those for presentations, were made with a silver join which could be engraved.
                                  If the repair isn't as tidy as you would like a thin tube of suitable material could be fashioned to cover the join, could even be silver and engraved, very thin so no real weight.
                                  Jon Lawes
                                    @jonlawes51698
                                    How on earth did he snap it!
                                    I wonder if the cleaner solution would be to get another piece of carbon fibre and replace the shaft complete? Rods are easily found, used in everything from Model RC Aircrft and and Fishing rods as metioned before.
                                    #592704
                                    pgk pgk
                                      @pgkpgk17461
                                      Trim the broken ends and bond into a pair of threaded gizmos for the ultimate in collapsible batons or as suggested fishing rod joiners. If sleeving the break it may be worth looking at arrow shafting if there is suitable size.
                                      Pgk
