All went well fitting the scales, and all seems to be accurate and repeatable,
I have set the direction to what I think is conventional:
Y increases if the table is moved back, X increases if the table moves left.
i have been using the mill for a couple of months now without any issues.
I have seen something today that I do not think is right.
If I set up a line hole position right/up the line is actually right/down.
If I set up a bolt hole circle, the holes are mirrored in the Y direction.
I have found someone's video on YouTube that demonstrates this:
(jump to 13 minutes into the video).
I think I have 2 options: Invert the Y direction so that Y increases if the table moves forward, or remember that the angle must be reversed when defining the pattern.
Has anyone else seen this, or am I doing something silly?
Edited By IRT on 06/02/2021 23:39:56
